Romeo84 Posted May 2, 2022 Share Posted May 2, 2022 Hey guys don't know much about the roller system just know I saw a mark on the floor when I extended the slide-out. Took out the kitchen cabinet fake floor to have a look and saw this. Is the nylon a cover? Is it missing broken or just supposed to be centered? Link to comment Share on other sites More sharing options...
willbo777 Posted May 2, 2022 Share Posted May 2, 2022 Looks like it is missing half of the plastic coating. Link to comment Share on other sites More sharing options...
jacwjames Posted May 2, 2022 Share Posted May 2, 2022 Here is a link to a supplier of roller, looks like your missing half of the covering. https://casshudson.com/collections/rv-rollers-brackets Link to comment Share on other sites More sharing options...
Romeo84 Posted May 2, 2022 Author Share Posted May 2, 2022 Ya that's what I was kinda thinking. Thanks for the link. Is it serviceable in place. Like just a simple swap? Any chance anyone knows which part it might be? Link to comment Share on other sites More sharing options...
jacwjames Posted May 2, 2022 Share Posted May 2, 2022 I pulled one of my rollers in the kitchen slide completely out, not hard. I'd suggest pulling the roller out and see if you can find any identifying marks on it. Take some measurements, length, diameter of roller, length of roller etc. Compare to the rollers on the link. You might have to call REV parts. 1 Link to comment Share on other sites More sharing options...
Romeo84 Posted May 3, 2022 Author Share Posted May 3, 2022 Is the roller bolted in or is it just a push pin like a toilet paper roll Link to comment Share on other sites More sharing options...
Steve's Bus Posted May 3, 2022 Share Posted May 3, 2022 I am in the process of replacing all 4 of my Slide rollers on my 2001 Monaco Signature. I purchased my rollers from https://shop.findmyrvparts.com/monaco-rv-slide-out-roller-clear-cover-08408530-p/190255.htm The roller you have pictured is the rear one under the sink. If I’m correct you just remove the 2 3/8 bolts and the roller and brackets lift straight up and out. Once removed you will see there is a Allen set screw in bottom of bracket Once you remove roller make sure there is no damage to the floor, check floor in slide extended position. Hopefully this will help! Good Luck 1 Link to comment Share on other sites More sharing options...
jacwjames Posted May 3, 2022 Share Posted May 3, 2022 My roller bolted in, looks like this https://revrvparts.com/item-detail?itemId=31820&organizationId=9 Link to comment Share on other sites More sharing options...
Steve's Bus Posted May 3, 2022 Share Posted May 3, 2022 The picture that shows his roller , is just like mine and the roller in my link will replace roller only. Reuse his brackets! I have been told Monaco went to your design roller with a single bolt adjustment to help to eliminate the roller damaging the nylon cover. This being caused by unequal load on each end of roller by miss adjustment. Link to comment Share on other sites More sharing options...
96 EVO Posted May 3, 2022 Share Posted May 3, 2022 1 hour ago, Romeo84 said: Is the roller bolted in or is it just a push pin like a toilet paper roll LOL! The only thing on these rig's that are as easy to change as a toilet paper roll is..... a toilet paper roll 🤣! 2 Link to comment Share on other sites More sharing options...
Steve's Bus Posted May 3, 2022 Share Posted May 3, 2022 On mine one end of the roller shaft will depress inward, but mine had set screws tightened down against shaft and would not move. Also because of the opening size being very close to the roller size it would be impossible to remove roller without removing at least one end of the mounting brackets. Link to comment Share on other sites More sharing options...
Romeo84 Posted May 3, 2022 Author Share Posted May 3, 2022 1 hour ago, Steve's Bus said: I am in the process of replacing all 4 of my Slide rollers on my 2001 Monaco Signature. I purchased my rollers from https://shop.findmyrvparts.com/monaco-rv-slide-out-roller-clear-cover-08408530-p/190255.htm The roller you have pictured is the rear one under the sink. If I’m correct you just remove the 2 3/8 bolts and the roller and brackets lift straight up and out. Once removed you will see there is a Allen set screw in bottom of bracket Once you remove roller make sure there is no damage to the floor, check floor in slide extended position. Hopefully this will help! Good Luck Hey man thanks for the help! Did your remove the roller while slide was extended? Is it easier one way or the other? Thanks again! Link to comment Share on other sites More sharing options...
Steve's Bus Posted May 3, 2022 Share Posted May 3, 2022 From what I understand it makes no difference where slide is positioned upon removal. Personally I removed and reinstalled mine with slide 1/2 way out. Hope this Helps! Link to comment Share on other sites More sharing options...
Ivan K Posted July 5, 2022 Share Posted July 5, 2022 On 5/2/2022 at 3:32 PM, Romeo84 said: Hey guys don't know much about the roller system just know I saw a mark on the floor when I extended the slide-out. Took out the kitchen cabinet fake floor to have a look and saw this. Is the nylon a cover? Is it missing broken or just supposed to be centered? Ryan, have you replaced the roller and was Steve's link a direct fit? I just noticed same thing on our kitchen roller, except the nylon is being shaved by it's bracket on the opposite side. Must be an adjustment thing, pushing the sleeve to one side. I would not know if my wife didn't notice the shavings and suspect a mouse... I measure the distance between brackets at about 10.5". Link to comment Share on other sites More sharing options...
Romeo84 Posted July 5, 2022 Author Share Posted July 5, 2022 I did order it and it looks close I have yet to install. Mine was 10.5 as well. I was thinking of trying to just replace the nylon roller. It's just a cover but haven't got around to that yet. Keep me in the loop if you get to 1st. Wanna know what om in for lol 1 Link to comment Share on other sites More sharing options...
