Bruce Hull Posted July 13, 2022 Share Posted July 13, 2022 I'm having trouble With the top pin in the door jam. Going after the rattles and fond the top pin was not Laching so i adjust it, then closing the door 2 or 3 times the pin moves so i put it back and get it as tight as i can, work the door and it moves again?? What I'm i doing wrong?? Or what trick do i need to do? Tks Bruce 2003 Monaco Windsor 38PDQ Link to comment Share on other sites More sharing options...
cbr046 Posted July 13, 2022 Share Posted July 13, 2022 Is the pin screw loose again? If so try some BLUE loctite. This may or may not be enough but what I would try first. Red loctite is much stronger but requires a torch to break free if it ever needs to be removed. - bob Link to comment Share on other sites More sharing options...
Tom Cherry Posted July 13, 2022 Share Posted July 13, 2022 50 minutes ago, Bruce Hull said: I'm having trouble With the top pin in the door jam. Going after the rattles and fond the top pin was not Laching so i adjust it, then closing the door 2 or 3 times the pin moves so i put it back and get it as tight as i can, work the door and it moves again?? What I'm i doing wrong?? Or what trick do i need to do? Tks Bruce 2003 Monaco Windsor 38PDQ Search the files and topics on adjusting the door. There is a file that covers the procedure. Maybe Monaco_Door_Adjust.PDF? There are TWO types of Trimark doors. You have to first identify whether yours has the bronze bushing or not. Odds are, based on the age, it does. If the bushing is worn, then it must be replaced….and then, you adjust it. There was, I believe, a detailed print and PN for easily fabricating a replacement. I called Trimark and the tech told me that you could not identify the different assemblies without taking the lock or latch assembly apart. I had read that, odds were, mine was the newer design and did not have the bushing. I had it adjusted. It did not have the bushing. The most common issue is the latch assembly moves or “wears in” and the handle will not release and you can’t get out or in and you have to disassemble it from the inside. Several YouTube videos. Lots of info on “Trimark RV door adjustment” 1 Link to comment Share on other sites More sharing options...
MyronTruex Posted July 13, 2022 Share Posted July 13, 2022 Here are a bunch of files on doors. There are a couple that shows how to adjust and repair. I'm not exactly clear on how your door is built, but if you are talking about the large bolts that stick out from the frame that the latches connect to then mine are designed to move up and down a bit. 7-8-2011 1-01-00 PM.pdf 7-8-2011 1-01-28 PM.pdf 7-8-2011 1-02-37 PM.pdf 7-8-2011 1-03-12 PM.pdf 7-8-2011 1-03-33 PM.pdf 7-8-2011 1-03-53 PM.pdf 7-8-2011 1-04-17 PM.pdf 7-8-2011 1-04-43 PM.pdf 7-8-2011 1-05-35 PM.pdf 7-8-2011 1-06-13 PM.pdf 7-8-2011 1-07-00 PM.pdf 7-8-2011 1-07-55 PM.pdf 7-8-2011 1-10-55 PM.pdf 7-8-2011 1-11-42 PM.pdf 7-8-2011 1-12-04 PM.pdf 7-8-2011 1-12-31 PM.pdf 7-8-2011 1-13-08 PM.pdf 7-8-2011 1-14-15 PM.pdf 7-8-2011 1-14-56 PM.pdf 7-8-2011 1-15-19 PM.pdf 7-8-2011 1-16-00 PM.pdf 7-8-2011 1-16-18 PM.pdf 7-8-2011 1-16-40 PM.pdf 7-8-2011 1-17-04 PM.pdf 7-8-2011 1-17-38 PM.pdf 7-8-2011 12-59-47 PM.pdf Bay door breakdown.pdf Bay door components.pdf Bay door latches and handles.pdf Bay door seals.pdf Bay Liners.pdf Cargo tray slideout.pdf Doors and vent covers.pdf Engine access doors and hardware.pdf 7-8-2011 1-05-35 PM.pdf 7-8-2011 1-06-13 PM.pdf 7-8-2011 1-07-00 PM.pdf 7-8-2011 1-07-55 PM.pdf 7-8-2011 1-10-55 PM.pdf 7-8-2011 1-11-42 PM.pdf 7-8-2011 1-13-08 PM.pdf 7-8-2011 1-14-15 PM.pdf Door Bushing Replacement & Latch Adjustment.pdf Entry door adjustment.pdf Entry door grab handle.pdf Entry door locked out pdf.pdf Youtube video on replacing latch.docx Entry door seals.pdf Entry door threshold.pdf Entry door trim.pdf Entry door with electric lock.pdf Entry screen door handle.pdf Entry screen door.pdf Keyless Entry.pdf Entry door adjustment.pdf desktop.ini Door adjustment web page.docx Entry Door Strut.pdf Gas Strut replaces swing arm.pdf Gas Strut Specifications.pdf Monaco_door_gas_strut_upgrade.pdf Parts list from Monaco users.pdf Generator door hardware.pdf Generator door.pdf Hatches and deck hatches.pdf Keyless Entry Consumer, discrete, e-Grab w_wo DB_22271-02_2010-04_Rev_4.pdf Keyless Entry Install, Discrete, e-Grab, stnd, w_wo DB_22271-03_2010-04_Rev_3.pdf Keyless Entry Install, Discrete, e-PAD_only_21067-01_2010-11-Rev_3.pdf Keyless entry picture from IRV2.com.pdf Keyless Entry Tri Mark.pdf Keyless Entry.pdf keyless_entry_diagram.pdf Keypad Entry.pdf Keyless Entry.pdf Entry Door Strut.pdf Gas Strut replaces swing arm.pdf Monaco Parts store swing arm assembly.url Monaco Parts store swingarm assembly (VEURINKS) if link does not work.url Monaco_door_gas_strut_upgrade.pdf Swing Arm and more.pdf Swing arm.pdf https://www.youtube.com/watch?v=D6-SFexjNuU This is a video link buried in one of the files. I added a file with the link in it for easier future reference. https://www.youtube.com/watch?v=D6-SFexjNuU This is a video link buried in one of the files. I added a file with the link in it for easier future reference. IF you have the large bolts from the frame as I do, then a few wraps of good electrical tape should help the rattling noise. I have chased rattles for years and mostly solved them. Using the round sticky back felt pads in various places has solved most of the issues. Latching the deadbolt while traveling helps as well. I'm envious of those that have some sort of inflatable seal. Link to comment Share on other sites More sharing options...
Tom Cherry Posted July 13, 2022 Share Posted July 13, 2022 22 minutes ago, myrontruex said: Here are a bunch of files on doors. There are a couple that shows how to adjust and repair. I'm not exactly clear on how your door is built, but if you are talking about the large bolts that stick out from the frame that the latches connect to then mine are designed to move up and down a bit. 7-8-2011 1-01-00 PM.pdfUnavailable 7-8-2011 1-01-28 PM.pdfUnavailable 7-8-2011 1-02-37 PM.pdfUnavailable 7-8-2011 1-03-12 PM.pdfUnavailable 7-8-2011 1-03-33 PM.pdfUnavailable 7-8-2011 1-03-53 PM.pdfUnavailable 7-8-2011 1-04-17 PM.pdfUnavailable 7-8-2011 1-04-43 PM.pdfUnavailable 7-8-2011 1-05-35 PM.pdfUnavailable 7-8-2011 1-06-13 PM.pdfUnavailable 7-8-2011 1-07-00 PM.pdfUnavailable 7-8-2011 1-07-55 PM.pdfUnavailable 7-8-2011 1-10-55 PM.pdfUnavailable 7-8-2011 1-11-42 PM.pdfUnavailable 7-8-2011 1-12-04 PM.pdfUnavailable 7-8-2011 1-12-31 PM.pdfUnavailable 7-8-2011 1-13-08 PM.pdfUnavailable 7-8-2011 1-14-15 PM.pdfUnavailable 7-8-2011 1-14-56 PM.pdfUnavailable 7-8-2011 1-15-19 PM.pdfUnavailable 7-8-2011 1-16-00 PM.pdfUnavailable 7-8-2011 1-16-18 PM.pdfUnavailable 7-8-2011 1-16-40 PM.pdfUnavailable 7-8-2011 1-17-04 PM.pdfUnavailable 7-8-2011 1-17-38 PM.pdfUnavailable 7-8-2011 12-59-47 PM.pdfUnavailable Bay door breakdown.pdfUnavailable Bay door components.pdfUnavailable Bay door latches and handles.pdfUnavailable Bay door seals.pdfUnavailable Bay Liners.pdfUnavailable Cargo tray slideout.pdfUnavailable Doors and vent covers.pdfUnavailable Engine access doors and hardware.pdfUnavailable 7-8-2011 1-05-35 PM.pdfUnavailable 7-8-2011 1-06-13 PM.pdfUnavailable 7-8-2011 1-07-00 PM.pdfUnavailable 7-8-2011 1-07-55 PM.pdfUnavailable 7-8-2011 1-10-55 PM.pdfUnavailable 7-8-2011 1-11-42 PM.pdfUnavailable 7-8-2011 1-13-08 PM.pdfUnavailable 7-8-2011 1-14-15 PM.pdfUnavailable Door Bushing Replacement & Latch Adjustment.pdfUnavailable Entry door adjustment.pdfUnavailable Entry door grab handle.pdfUnavailable Entry door locked out pdf.pdfUnavailable Youtube video on replacing latch.docxUnavailable Entry door seals.pdfUnavailable Entry door threshold.pdfUnavailable Entry door trim.pdfUnavailable Entry door with electric lock.pdfUnavailable Entry screen door handle.pdfUnavailable Entry screen door.pdfUnavailable Keyless Entry.pdfUnavailable Entry door adjustment.pdfUnavailable desktop.iniUnavailable Door adjustment web page.docxUnavailable Entry Door Strut.pdfUnavailable Gas Strut replaces swing arm.pdfUnavailable Gas Strut Specifications.pdfUnavailable Monaco_door_gas_strut_upgrade.pdfUnavailable Parts list from Monaco users.pdfUnavailable Generator door hardware.pdfUnavailable Generator door.pdfUnavailable Hatches and deck hatches.pdfUnavailable Keyless Entry Consumer, discrete, e-Grab w_wo DB_22271-02_2010-04_Rev_4.pdfUnavailable Keyless Entry Install, Discrete, e-Grab, stnd, w_wo DB_22271-03_2010-04_Rev_3.pdfUnavailable Keyless Entry Install, Discrete, e-PAD_only_21067-01_2010-11-Rev_3.pdfUnavailable Keyless entry picture from IRV2.com.pdfUnavailable Keyless Entry Tri Mark.pdfUnavailable Keyless Entry.pdfUnavailable keyless_entry_diagram.pdfUnavailable Keypad Entry.pdfUnavailable Keyless Entry.pdfUnavailable Entry Door Strut.pdfUnavailable Gas Strut replaces swing arm.pdfUnavailable Monaco Parts store swing arm assembly.urlUnavailable Monaco Parts store swingarm assembly (VEURINKS) if link does not work.urlUnavailable Monaco_door_gas_strut_upgrade.pdfUnavailable Swing Arm and more.pdfUnavailable Swing arm.pdfUnavailable https://www.youtube.com/watch?v=D6-SFexjNuU This is a video link buried in one of the files. I added a file with the link in it for easier future reference. https://www.youtube.com/watch?v=D6-SFexjNuU This is a video link buried in one of the files. I added a file with the link in it for easier future reference. IF you have the large bolts from the frame as I do, then a few wraps of good electrical tape should help the rattling noise. I have chased rattles for years and mostly solved them. Using the round sticky back felt pads in various places has solved most of the issues. Latching the deadbolt while traveling helps as well. I'm envious of those that have some sort of inflatable seal. Try this one. It is, to me, the most complete. The tech that did mine said it was great and he had done several. monaco_door_adjust.pdf Link to comment Share on other sites More sharing options...
Cubflyer Posted July 13, 2022 Share Posted July 13, 2022 2 hours ago, Bruce Hull said: I'm having trouble With the top pin in the door jam. Going after the rattles and fond the top pin was not Laching so i adjust it, then closing the door 2 or 3 times the pin moves so i put it back and get it as tight as i can, work the door and it moves again?? What I'm i doing wrong?? Or what trick do i need to do? Tks Bruce 2003 Monaco Windsor 38PDQ Bruce, Are you having trouble with the door or the frame the door closes into? Seems most of the advise given is for the door itself..... I believe the "pins" that the door latches to on in the frame are actually designed to "float". Ken Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted July 17, 2022 Share Posted July 17, 2022 On 7/13/2022 at 6:12 AM, Bruce Hull said: I'm having trouble With the top pin in the door jam. Going after the rattles and fond the top pin was not Laching so i adjust it, then closing the door 2 or 3 times the pin moves so i put it back and get it as tight as i can, work the door and it moves again?? What I'm i doing wrong?? Or what trick do i need to do? Tks Bruce 2003 Monaco Windsor 38PDQ The top pin is designed to move so that if the latch gets slightly out of adjustment, the latch will engage. Chuck B 2004 Windsor 1 Link to comment Share on other sites More sharing options...
Bruce Hull Posted July 17, 2022 Author Share Posted July 17, 2022 Sorry. so long to reply,, that makes sense,, thats whats its doing!! Just not locking up?? The lock works if i used a screwdriver?? I'll play with it again thanks. let you know if i get it!!! May be a week or two .. still have a full-time job!! Hope to retire in a couple year Link to comment Share on other sites More sharing options...
