bonfield Posted October 4, 2022 Share Posted October 4, 2022 I am tryng to replace my cigarette lighter on the dash with a built in duel usb port but i am unavle to remove the old lighter any tricks to it no nut on back Link to comment Share on other sites More sharing options...
gdroberson Posted October 4, 2022 Share Posted October 4, 2022 the back unscrews you stick something in the inside and the back unscrews off Link to comment Share on other sites More sharing options...
Chad A Posted October 5, 2022 Share Posted October 5, 2022 Exactly. Did what you are doing to mine. Just unscrew the entire back of it. Link to comment Share on other sites More sharing options...
cbr046 Posted October 5, 2022 Share Posted October 5, 2022 It's sort of an inner and outer shell on the backside. They unscrew apart. No tools needed. - bob Link to comment Share on other sites More sharing options...
RBRODDER Posted October 5, 2022 Share Posted October 5, 2022 Make sure the power is off to the lighter prior to attempting to remove it...especially if you need to stick something inside of it to hold it while removing the rear housing. Link to comment Share on other sites More sharing options...
cbr046 Posted October 5, 2022 Share Posted October 5, 2022 5 hours ago, RBRODDER said: Make sure the power is off to the lighter prior to attempting to remove it...especially if you need to stick something inside of it to hold it while removing the rear housing. Live dangerously. Just pull the connector first. On a 2003 Endeavor one of the 2 accessory socket fuses is unlabled in the fuse panel (FRB). - bob Link to comment Share on other sites More sharing options...
