CTerry Posted October 12, 2022 Share Posted October 12, 2022 I have a 2003 Beaver Monterey. Does anyone know where the resistor for the AC/Heater fan motor is and how to get to it. Operating on just 3rd speed now. Would like to fix it but can't find it. Thanks for the help/ Link to comment Share on other sites More sharing options...
Cubflyer Posted October 12, 2022 Share Posted October 12, 2022 Those fan resistors are usually mounted on the evaporator box so that they are inside with airflow over them to keep them cool… look around on the outside of the box for something with wires that is screwed on… 1 Link to comment Share on other sites More sharing options...
veraken Posted October 14, 2022 Share Posted October 14, 2022 (edited) Here is a recent link from the IRV2 forum on this topic. https://www.irv2.com/forums/f115/assistance-in-removing-the-dash-air-heater-blower-motor-in-a-1999-monaco-windsor-588493.html I just replaced the resistor pack on mine. This is what I used. https://www.ebay.com/itm/392473938086 Edited October 14, 2022 by veraken Link to comment Share on other sites More sharing options...
CTerry Posted October 15, 2022 Author Share Posted October 15, 2022 My problem is I havent't been able to find the location of the resistor. Thanks for the links for sourcing it. Link to comment Share on other sites More sharing options...
Happycarz Posted October 17, 2022 Share Posted October 17, 2022 Open the generator compartment and look left and high. There is a plastic box that the heater hoses go to, along with the A/C lines. On top of that box is the resistor. And a view of a virgin A/C box. Link to comment Share on other sites More sharing options...
CTerry Posted October 18, 2022 Author Share Posted October 18, 2022 Thanks for the picture. My unit seems to be different but will look again. Link to comment Share on other sites More sharing options...
Frank McElroy Posted October 18, 2022 Share Posted October 18, 2022 Terry, If you can, please post pictures like Harry did. It would held to know the model of the AC evaporator assembly. My memory is a bit fuzzy, but I seem to recall posts on one of the forums a while back about the resistor block on some units being on the interior side of the firewall. Pictures of your unit would really help. Link to comment Share on other sites More sharing options...
CTerry Posted October 18, 2022 Author Share Posted October 18, 2022 I believe mine is on the inside. I had the dash off and could see the unit but couldn't find the resistor. Put it back together and then traced the wiring from the rotary switch to the front of the firewall where it goes through. Has got to be under the dash on the passenger side. We have a couple of short trips planned then I will try that again. Thanks for the info. Link to comment Share on other sites More sharing options...
Bob R Posted November 18, 2022 Share Posted November 18, 2022 I have a failed speed control as well. I suppose it is the resistor pack that is the problem. The 3rd speed works. However, the heater fan is terribly noisy. The bearings must be failed. I need to get to the fan and cannot see how to get to it to remove it and replace it. I have removed the drawers that are on the passenger side of the dash and the cover for the AH blower at the bottom of the center console but can see no attachment points for the dash itself. Has anyone accessed this fan on a 2005 Dynasty? If so, I would sure appreciate some guidance. I have looked for the resistor pack and have not been able to locate it either. I looked around the AC evaporator on the outside firewall and didn't see any wiring that may have been attached to the resistors. I hate to destroy the dash and surrounds by trying to access the blower. Bob R 2005 Dynasty Countess lll Link to comment Share on other sites More sharing options...
