TomV48 Posted December 5, 2022 Share Posted December 5, 2022 (edited) Well, try as I will I cannot get the quarter inch fluid sampling tube down the dipstick tube to the fluid. Can't get it down the fill spout to the fluid. And cannot get it down the transmission fill spout to the fluid. Vacuum pump seems to work fine. 2005 Ambassador with Cummins 8.3 Haven't even tried to find the radiator cap yet although I took sample from the overflow tank I don't think that's a valid sample. The two vacuum pumps they gave me with the kit both work just fine Edited December 5, 2022 by TomV48 Link to comment Share on other sites More sharing options...
cbr046 Posted December 5, 2022 Share Posted December 5, 2022 I had to cut the end of the tube into a chisel point and even then it was challenging. - bob Link to comment Share on other sites More sharing options...
jacwjames Posted December 5, 2022 Share Posted December 5, 2022 I didn't bother getting the sampling vacuum kits. I just use a small clear tube and large syringe. Works great. https://www.amazon.com/Syringes-Scientific-Measuring-Dispensing-Refilling/dp/B08CV1KR5W/ref=sr_1_4?keywords=150ml+Large+Plastic+Syringes+with+2pcs+47in+Handy+Plastic+Tubing+and+Luer+Connections%2C&qid=1670247827&sr=8-4 I buy more tubing from Lowes. I had to get creative when I was changing my steering pump on my jeep, the tubing I had was too big to get down some of the hoses, went to Lowes and bought a roll of small fuel line in the lawn and garden department, this is used on weed wackers etc. It did fit down the line I wanted to evacuate. Link to comment Share on other sites More sharing options...
tmw188 Posted December 5, 2022 Share Posted December 5, 2022 X2 the trick is to cut the tube on a ~45 deg angle Link to comment Share on other sites More sharing options...
96 EVO Posted December 5, 2022 Share Posted December 5, 2022 15 hours ago, TomV48 said: Haven't even tried to find the radiator cap yet although I took sample from the overflow tank I don't think that's a valid sample. Sure you have an overflow tank? Your radiator cap will be on the surge tank, and you will be fine collecting your sample from there. 1 Link to comment Share on other sites More sharing options...
TomV48 Posted December 7, 2022 Author Share Posted December 7, 2022 On 12/5/2022 at 2:52 PM, 96 EVO said: Sure you have an overflow tank? Your radiator cap will be on the surge tank, and you will be fine collecting your sample from there. The lab instruction spoke of that like a last resort. But it is what I did. Thanks Link to comment Share on other sites More sharing options...
96 EVO Posted December 7, 2022 Share Posted December 7, 2022 11 hours ago, TomV48 said: The lab instruction spoke of that like a last resort. But it is what I did. Thanks They are talking about an overflow tank, which see's very little fluid turnover. The coolant in your surge tank is constantly making a trip through your engine / dash heating system. 1 Link to comment Share on other sites More sharing options...
