Doug, W5WTX Posted April 14, 2023 Share Posted April 14, 2023 Checking out my 2006 Dynasty Pltinum IV getting it ready to roll. My HWH Air Leveling panel is dead. No lights lit and non responsive. Also Tag Axel air dump is non responsive. Both air tanks are full and holding. Checked fuses in the driver side control panel under the cockpit. All fuses are good. Is there a hidden fuse or master reset lurking on my rig? Any first step trouble shooting advice is welcome. Doug Link to comment Share on other sites More sharing options...
Ivan K Posted April 14, 2023 Share Posted April 14, 2023 I don't know if you have a reset switch, I don't but it isn't unusual for the connecting cable under the pad to get loose and not as likely but also happens on its other end in the controller box. Since you FRB fuses checked out, there is bunch more on the controller board but these are for specific functions, wouldn't necessarily cause no lights on touch pad. Link to comment Share on other sites More sharing options...
Doug, W5WTX Posted April 14, 2023 Author Share Posted April 14, 2023 I just crawled out of the center bay and checked all the fuses in the HWH box. All good. I’ll pull the panel next. Dang thing was working just a couple weeks ago. Rig hasn’t moved since then. doug Link to comment Share on other sites More sharing options...
Ivan K Posted April 14, 2023 Share Posted April 14, 2023 Hopefully not a mouse job, I had them in the controller box last year. I suppose you checked for power in the box. Our humidity also makes wonders here. Link to comment Share on other sites More sharing options...
SteveC Posted April 14, 2023 Share Posted April 14, 2023 Check for voltage in the controller box itself. If you have power and ground, remove your keypad and connect directly to your controller box using a short cable. I got my cable from Amazon and it worked fine (link below). If it works, check the original wire from controller to keypad. I found mouse bites on mine. Repaired wire and all worked like new. https://www.amazon.com/gp/product/B00RFLMK5U/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 Mine was also working fine one day and failed the next. Good luck. Link to comment Share on other sites More sharing options...
det944 Posted April 14, 2023 Share Posted April 14, 2023 On my Dynasty I had a similar issue a couple of times. Once solved by HWH reset switch in the Front Run Box, red "fault light" was illuminated. Pushed the reset. The other time I forgot to turn on the salesman switch at the front door. Doing so restored HWH functions. Link to comment Share on other sites More sharing options...
vito.a Posted April 14, 2023 Share Posted April 14, 2023 Our HWH control panel quit working. The ground wire on the back of the panel had pulled lose. Link to comment Share on other sites More sharing options...
Georgia Mike Posted June 24, 2023 Share Posted June 24, 2023 Doug, did you ever find out what the problem was with your HWH panel? Link to comment Share on other sites More sharing options...
Solution Bruce B Posted June 25, 2023 Solution Share Posted June 25, 2023 I had the same problem and it turned out to be a bad circuit on the board that powered the HWH so a temporary work around on the board was done and I now carry a replacement board. The board was in the drivers side front run box. I hope this helps. Link to comment Share on other sites More sharing options...
Doug, W5WTX Posted June 26, 2023 Author Share Posted June 26, 2023 On 6/24/2023 at 7:29 AM, Georgia Mike said: Doug, did you ever find out what the problem was with your HWH panel? Yes. Initially I checked fuses but apparently missed one. There are two fuses on my rig located in the front run box. After seeing one and checking it I thought I was good. I missed a second fuse that is also part of the HWH system. My next task is to calibrate the system. The auto leveling does its thing but consistently is slightly off level. I have been simply manually tweaking. When I run out of other things to do, I’ll look into how to calibrate. doug 1 Link to comment Share on other sites More sharing options...
