powersltc Posted May 16, 2023 Share Posted May 16, 2023 Ron P. 2004 Monaco Executive Hello. I have an issue with my taillights and signal lights working at the same time. I have replaced all bulbs and sockets. Signal lights work. They will not work when I turn the taillights on. Any ideas/suggestions. Thanks Link to comment Share on other sites More sharing options...
Marine Boy Posted May 16, 2023 Share Posted May 16, 2023 Most likely you have a bad ground. Try tapping in a ground connection at one of the tail lights an see if that solves your problem. If it does, then you will need to trace back the ground circuit for those lights. 1 Link to comment Share on other sites More sharing options...
Larry Maida Posted May 17, 2023 Share Posted May 17, 2023 Point of information, are the bulbs incandescent? I tried to switch all of my bulbs to LED but they will not work for directionals. Something with the fact that they do not draw enough current to trip the flash mechanism. Just saying. Link to comment Share on other sites More sharing options...
powersltc Posted May 17, 2023 Author Share Posted May 17, 2023 Hey. I tried to switch all to LED and realized the same problem. So I switched all back to regular bulbs. Taillights work when park and regular lights. Signal lights work when I turn off regular lights. Back up lights work. I haven't checked brake lights. Link to comment Share on other sites More sharing options...
Ivan K Posted May 17, 2023 Share Posted May 17, 2023 If the flasher is your only problem with leds, there are electronic flashers that are not based on current flow. I changed all lights to led except the directional ones where the current direction alternates, not worth the hassle for me at that time. Link to comment Share on other sites More sharing options...
Dave Pumphrey Posted May 18, 2023 Share Posted May 18, 2023 As others have mentioned, possibly bad ground. With the lights off, the turn signals can ground thru the run light filament. When I changed to LED's on my 2000 Dynasty, it has the lower marker light connected to the run circuit and the turn circuit. With the turn signal off, the bulb would ground thru the signal filament. With lights on, it would blink opposite the turn signal, as it could ground the bulb between blinks. The LED bulbs won't provide this ground thru the bulb, because they are polarity specific. My solution was to disconnect the wire to the signal, & ground it, making the light a running light only. I did think about a dual filament bulb, but haven't had that much "spare" time. My turn signal flasher operates a relay, so no problem with the lighter load not triggering the flasher... 1 Link to comment Share on other sites More sharing options...
powersltc Posted May 18, 2023 Author Share Posted May 18, 2023 1 hour ago, Dave Pumphrey said: As others have mentioned, possibly bad ground. With the lights off, the turn signals can ground thru the run light filament. When I changed to LED's on my 2000 Dynasty, it has the lower marker light connected to the run circuit and the turn circuit. With the turn signal off, the bulb would ground thru the signal filament. With lights on, it would blink opposite the turn signal, as it could ground the bulb between blinks. The LED bulbs won't provide this ground thru the bulb, because they are polarity specific. My solution was to disconnect the wire to the signal, & ground it, making the light a running light only. I did think about a dual filament bulb, but haven't had that much "spare" time. My turn signal flasher operates a relay, so no problem with the lighter load not triggering the flasher... Thanks. The daylight run light sounds good. Link to comment Share on other sites More sharing options...
Dave Pumphrey Posted May 18, 2023 Share Posted May 18, 2023 I'm talking about the lower marker lights at the rear, not daytime running lights... Link to comment Share on other sites More sharing options...
powersltc Posted May 18, 2023 Author Share Posted May 18, 2023 Oh. Link to comment Share on other sites More sharing options...
Les Hurdle Posted May 28, 2023 Share Posted May 28, 2023 2004 cheetah. I've tried various bulbs incl led but they all seem so low in 'power'. I had purchased Bargman for my Fleetwood but don't see anything which would replace the Cheetah assemblies. Anyone know of assemblies or super bright bulbs? Thanks. Les Link to comment Share on other sites More sharing options...
powersltc Posted May 30, 2023 Author Share Posted May 30, 2023 I haven't fixed lights yet. I have an appointment on 14 June. Hopefully they can figure out the problem. Link to comment Share on other sites More sharing options...
