Jeff sams Posted June 9, 2023 Share Posted June 9, 2023 Anybody know specific transmission fluid for slide room hydraulic tank ? Link to comment Share on other sites More sharing options...
Solution Ivan K Posted June 9, 2023 Solution Share Posted June 9, 2023 Check the color of your fluid. Mine is red ATF Dexron. The new Dexrons are back compatible with the older lower versio number, just check the label if you have the same. Link to comment Share on other sites More sharing options...
vito.a Posted June 9, 2023 Share Posted June 9, 2023 (edited) Found this: What fluid do I use in a HWH leveling system? HWH Hydraulic Oil HWH Hydraulic Oil is a clear hydraulic oil manufactured by Conoco, exclusively for HWH Corporation, for use in HWH Hydraulic Leveling Systems and Hydraulic Room Extension Systems. https://www.campingworld.com/hwh-hydraulic-fluid-32-oz.-20763.html HWH manual says that their stuff is recommended, but Dexron transmission fluid can be used in an emergency. The only negative they state is that Dexron has a red color which might stain the floor. Edited June 9, 2023 by vito.a 1 Link to comment Share on other sites More sharing options...
Jeff sams Posted June 9, 2023 Author Share Posted June 9, 2023 Thanks guys! Link to comment Share on other sites More sharing options...
Frank McElroy Posted June 10, 2023 Share Posted June 10, 2023 6 hours ago, vito.a said: Found this: What fluid do I use in a HWH leveling system? HWH Hydraulic Oil HWH Hydraulic Oil is a clear hydraulic oil manufactured by Conoco, exclusively for HWH Corporation, for use in HWH Hydraulic Leveling Systems and Hydraulic Room Extension Systems. https://www.campingworld.com/hwh-hydraulic-fluid-32-oz.-20763.html HWH manual says that their stuff is recommended, but Dextron transmission fluid can be used in an emergency. The only negative they state is that Dexron has a red color which might stain the floor. I also used the HWH fluid. It's clear and I didn't want the red stain of Trans fluid in case of a leak. Link to comment Share on other sites More sharing options...
