Rick A Posted June 29, 2023 Share Posted June 29, 2023 I change my oil and filter a year ago and drove it about 800km on new oil and filter. Should I change the oil now, I know it’s a year! Thanks. Link to comment Share on other sites More sharing options...
timaz996 Posted June 29, 2023 Share Posted June 29, 2023 In my view no 3 Link to comment Share on other sites More sharing options...
AndyinMelbourne Posted June 29, 2023 Share Posted June 29, 2023 I have a 2005 Windsor with 400 ISL. I personally wouldn't change the oil right at 1 year with that few miles on it. We run ours 11,000 miles per year traveling to visit family and generally do change annually but for that few miles I would probably let it go 6 months or a year later. There are a lot of varying opinions on this though. 2 Link to comment Share on other sites More sharing options...
Solution Trinidaddave Posted June 29, 2023 Solution Share Posted June 29, 2023 You could always pull an oil sample and send in for analysis with someone like Blackstone Laboratories. You can get a pump from them and pull the oil through the dipstick. They will track your samples and provide recommendations on future changes. 5 Link to comment Share on other sites More sharing options...
dl_racing427 Posted June 29, 2023 Share Posted June 29, 2023 Two years is very safe to run oil when you don't run a lot of miles. Even longer if stored indoors. One thing you don't want is short trips or unnecessary startups where you don't get the oil up to normal temperature. If in doubt, oil analysis is always an option. 1 Link to comment Share on other sites More sharing options...
Rick A Posted June 29, 2023 Author Share Posted June 29, 2023 I think I’m okay but I will get an oil analysis. 1 Link to comment Share on other sites More sharing options...
96 EVO Posted June 29, 2023 Share Posted June 29, 2023 Only time I'd be changing it at 12mo and 800km, is if it was still under warrantee. Wouldn't want to give them a reason to deny a warrantee claim! Link to comment Share on other sites More sharing options...
Guest Ray Davis Posted June 29, 2023 Share Posted June 29, 2023 Speedco used to do oil analysis, & they probably still do. It's done by a machine, and I don't know if that's good or bad. I think you can take in a sample and wait a few minutes for a printout. Link to comment Share on other sites More sharing options...
Ivylog Posted June 30, 2023 Share Posted June 30, 2023 HELL NO!!! While I recommend oil samples, with that few miles it’s not going to tell you much. I take a sample around 12,000 miles to see how much longer I can go… likely another 8,000 miles and 3 years. Anyone changing annually on an engine that works hard, not driven 3 miles to church, is wasting $$. 2 Link to comment Share on other sites More sharing options...
Paul J A Posted July 1, 2023 Share Posted July 1, 2023 Send your fluid samples to; https://www.blackstone-labs.com/ They will tell you when it needs changing. Did it 10 years full timing. Saved $$$$$ , not throwing away good engine oil. This is a C & P from their site; Most of these tests can be combined with our Standard Oil Analysis. These tests can also be purchased in bulk as part of our bulk pricing program. For special combinations of tests or bulk pricing, please call us at (260) 744-2380. Our standard analysis costs $35.00. Link to comment Share on other sites More sharing options...
