PeterSchweizer Posted July 17, 2023 Share Posted July 17, 2023 2004 Monaco Cayman 34pdd 5.9 engine. While traveling today on Interstate 15 NB N of Ogden UT at about 68 MPH in Economy mode there was a downshift into 4th and it would never go back to 5th gear. NO Check Trans light or other service lights on, Tried manually shifting up n down or pressing D to go back intro D 5 or Economy MODE on n off several times (NOTE:MODE light does go on n off as it should when cycling into Economy mode) . Basically cycling it thru all the shifts no help. stopped repeated same, nothing, again turned coach off for several minuets no help. Fluid level and temperatures normal. Had to drive the last 40 miles to Lava Hot Springs in 4th gear at 55 MPH. So any Suggestions? None of my coaches manuals Monaco or Allison discuss how or if possible to retrieve any codes- just says call Allision customer service, which I will do in the AM. Also anyone know of any good Coach trans service shops in Pocatello ID? Link to comment Share on other sites More sharing options...
PeterSchweizer Posted July 17, 2023 Author Share Posted July 17, 2023 Note: I tried to retrieve codes per Tom Cherry's resent response July 15 2023 post of Shanners Mechanics life u tube viedo, but it never showed any codes? Link to comment Share on other sites More sharing options...
MurrayD Posted July 17, 2023 Share Posted July 17, 2023 Peter, when my alternator gave out on me I continued driving as the batteries went down. By the time I reached the next city voltage was under 9 volts and the transmission would not shift out of 6th gear. Is it possible your voltage is low? 1 Link to comment Share on other sites More sharing options...
Solution TW Racing Posted July 17, 2023 Solution Share Posted July 17, 2023 Could be Transmission fluid leaked into the wiring harness connection causing a short. We had that happen a few weeks ago in Az and then it would not go into gear at all and no codes could be found. Hopefully that’s all it is as now we are told we need a new transmission, the tech found metal shavings in the pan. wishing you the best of luck. 1 Link to comment Share on other sites More sharing options...
PeterSchweizer Posted July 17, 2023 Author Share Posted July 17, 2023 45 minutes ago, MurrayD said: Peter, when my alternator gave out on me I continued driving as the batteries went down. By the time I reached the next city voltage was under 9 volts and the transmission would not shift out of 6th gear. Is it possible your voltage is low? VOLTAGE IS GOOD THANKS 26 minutes ago, TW Racing said: Could be Transmission fluid leaked into the wiring harness connection causing a short. We had that happen a few weeks ago in Az and then it would not go into gear at all and no codes could be found. Hopefully that’s all it is as now we are told we need a new transmission, the tech found metal shavings in the pan. wishing you the best of luck. Just now, PeterSchweizer said: will clean connectors in AM thanks Just now, PeterSchweizer said: VOLTAGE IS GOOD THANKS Link to comment Share on other sites More sharing options...
cbr046 Posted July 17, 2023 Share Posted July 17, 2023 Probably NOT your issue, but when my primary fuel filter started clogging the very first symptom was the Allison MH4000 transmission not shifting back to 6th after a slight load (any hill) while in cruise control (only). Everything seemed fine in normal mode (cruise control off). My best guess was the transmission CU was sensing limited power and keeping it in the lower gear. It took a few trips and thousands of miles later but eventually the filter got so clogged I could barely make it up the slightest hill with ~10 lbs of boost. I was new to the whole "diesel thing" at the time. My point is that the ECU and TCU might be limiting power for some abstract issue. - bob 1 1 Link to comment Share on other sites More sharing options...
Dr4Film Posted July 17, 2023 Share Posted July 17, 2023 Hopefully the links below may help. https://www.irv2.com/forums/f125/allison-mh2000-wont-shift-to-5th-gear-94921.html https://www.rvtechlibrary.com/transmissions/1000_2000_operators.pdf 1 Link to comment Share on other sites More sharing options...
Agpopp Posted July 26, 2023 Share Posted July 26, 2023 As a Neptune owner, I'd like to hear how the issue was solved. Was the connection just cleaned and reinstalled? Link to comment Share on other sites More sharing options...
PeterSchweizer Posted August 14, 2023 Author Share Posted August 14, 2023 FIXED follow up - Cleaned all 5 electrical connectors on transmission and it has been working for the past 1000 miles. Thanks everyone this is a great source for fixen! 1 1 Link to comment Share on other sites More sharing options...
