timaz996 Posted August 19, 2023 Share Posted August 19, 2023 (edited) I have seen the answer to my question go both ways but here goes. What Roadmaster chassis type do I have on my 2000 Monaco Dynasty? The ID tag on the chassis shows model as R36000. I do have 8 out board airbags. Edited August 19, 2023 by timaz996 Link to comment Share on other sites More sharing options...
TomV48 Posted August 19, 2023 Share Posted August 19, 2023 (edited) Well ours is a 2005 Ambassador 34 and it is called RR8R. RAISED RAIL 8 airbag REAR RADIATOR. Our travel partners is a 2003 36 ft, and very similar except they have a side radiator. So it would be like the RR8S but it's got a number more like what you're describing as your chassis number. So there's a difference but I don't know what it is. Edited August 19, 2023 by TomV48 Link to comment Share on other sites More sharing options...
Rocketman3 Posted August 19, 2023 Share Posted August 19, 2023 My 2000 Dynasty is a RR8S: My understanding: RR - stands for Roadmaster or Raised Rail 8 - is the number of airbags S - is for Side Radiator (R is for Rear Radiator). 1 Link to comment Share on other sites More sharing options...
cbr046 Posted August 19, 2023 Share Posted August 19, 2023 There was a discussion on another thread where the "S" is believed to be for semi monocoque frame. - bob Link to comment Share on other sites More sharing options...
Solution waterskier_1 Posted August 19, 2023 Solution Share Posted August 19, 2023 According to the Monaco Brochure (attached) you have a "Semi-Monocoque Tubular Steel Frame" with 8 Air Bags. This is often referred to as an "S-Series" Chassis. It differs from the RR8S chassis which is a Raised Rail 8 Air bag Side Radiator design. The body structure of the Raised Rail (which refers to the steel frame) is mounted (bolted or welded) to the frame. The S-Series the body structure is part of the frame (kind of like Uni-Body autos) which can not be separated from the frame (and still have anything left). It is the top of the line of the Road Master Chassis that Monaco built. -Rick N. 2000_Dynasty.pdf 1 Link to comment Share on other sites More sharing options...
timaz996 Posted August 20, 2023 Author Share Posted August 20, 2023 UPDATE: Here is the information showing how to decode your vin number that shows what chassis and other equipment your coach has. PART 2_ Chassis Info-Known Problems-Engine Types.pdf Link to comment Share on other sites More sharing options...
cbr046 Posted August 20, 2023 Share Posted August 20, 2023 58 minutes ago, timaz996 said: UPDATE: Here is the information showing how to decode your vin number that shows what chassis and other equipment your coach has. PART 2_ Chassis Info-Known Problems-Engine Types.pdf 4.5 MB · 2 downloads Interesting read. Is there a Part 1 ? - bob Link to comment Share on other sites More sharing options...
timaz996 Posted August 20, 2023 Author Share Posted August 20, 2023 1 hour ago, cbr046 said: Interesting read. Is there a Part 1 ? - bob Part one is other chassis. Here is my post on IRV2 forum. https://www.irv2.com/forums/f115/what-roadmaster-chassis-do-i-have-623393.html 1 Link to comment Share on other sites More sharing options...
