DanVickie Posted September 16 Share Posted September 16 I’m just wondering about how much oil these take if I change the oil ? Can’t seem to find this anywhere . Any help on this appreciated , and how to do it. Thanks. 2006 Monaco Dynasty 43 king III Link to comment Share on other sites More sharing options...
Solution Ivan K Posted September 16 Solution Share Posted September 16 I think I used about a quart for the tags all together on my axle. I had a 5 gal bucket so that's an estimate. To change it, you'll have to suck it out with something if they have no drain plug and fill to the line. Easy, just give it few minutes to level out and check again. Don't overfill. 2 Link to comment Share on other sites More sharing options...
DanVickie Posted September 16 Author Share Posted September 16 Thank you, that’s what I was guessing , maybe more , Link to comment Share on other sites More sharing options...
Dr4Film Posted September 17 Share Posted September 17 Make sure to use a good quality synthetic oil. 2 Link to comment Share on other sites More sharing options...
dl_racing427 Posted September 17 Share Posted September 17 Lucas makes a dedicated hub oil. IIRC it is supposed to be very clingy, and particularly suited to corrosion prevention and moisture tolerance. A quart should be more than enough to fill a pair of hubs. Link to comment Share on other sites More sharing options...
DanVickie Posted September 18 Author Share Posted September 18 I know I have some Lucas 75/90 synthetic gear oil I used before, there is another specific hub oil ? Link to comment Share on other sites More sharing options...
dl_racing427 Posted September 18 Share Posted September 18 16 hours ago, DanVickie said: I know I have some Lucas 75/90 synthetic gear oil I used before, there is another specific hub oil ? https://www.amazon.com/Lucas-Oil-10088-Quart-Ounces/dp/B000IG7PM2/ref=asc_df_B000IG7PM2/?tag=hyprod-20&linkCode=df0&hvadid=312141533517&hvpos=&hvnetw=g&hvrand=4268387098620377167&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1014895&hvtargid=pla-449859396840&psc=1&tag=&ref=&adgrpid=61941536837&hvpone=&hvptwo=&hvadid=312141533517&hvpos=&hvnetw=g&hvrand=4268387098620377167&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1014895&hvtargid=pla-449859396840 Link to comment Share on other sites More sharing options...
DanVickie Posted September 18 Author Share Posted September 18 Not sure if we should use this , seems real thick according to this research . Nearly 4 times . Link to comment Share on other sites More sharing options...
DanVickie Posted September 19 Author Share Posted September 19 I copied and pasted this from the Amazon site under The Lucas hub oil , this is not me, my comment is at the bottom, “maybe we shouldn’t use this .” although I use some of their products and like them Link to comment Share on other sites More sharing options...
