SpottedJag96 Posted December 2, 2023 Share Posted December 2, 2023 As I was driving off to embark on yet another trip, I noticed the driver side of my coach was low. After inspecting, I heard a hiss coming from the area of the front driver side air bag. I replaced all the rear bags about a year ago, but haven't done the front yet. I lowered and raised the coach a few times and I don't hear anything leaking out. However, the driver side is still lower than the passenger side. Letting it sit, it hasn't gone down anymore and no hissing sounds. I'm wondering if it might be a leveling rod issue? I'm hesitant to drive the coach. Any suggestions? Link to comment Share on other sites More sharing options...
Ivan K Posted December 2, 2023 Share Posted December 2, 2023 If it is happening when the coach should be at ride hight and there are no air leaks, I would certainly look at the rear ride hight rod and valve adjustment. Link to comment Share on other sites More sharing options...
klcdenver Posted December 2, 2023 Share Posted December 2, 2023 You will need to adjust rear passenger side ride height valve to change drivers side. You will adjust the passenger rear to change the drivers side front. There is only one ride height valve in the front. It is connected to the center of the front axle. Link to comment Share on other sites More sharing options...
SpottedJag96 Posted December 2, 2023 Author Share Posted December 2, 2023 Is that something I can adjust myself or does it need to go to a shop? Link to comment Share on other sites More sharing options...
Bill R Posted December 2, 2023 Share Posted December 2, 2023 9 minutes ago, SpottedJag96 said: Is that something I can adjust myself or does it need to go to a shop? Procedure should be in your manual. Attached is the procedure for my coach, and likely for yours. Ride Height Adjustment Procedure.pdf Link to comment Share on other sites More sharing options...
SpottedJag96 Posted December 3, 2023 Author Share Posted December 3, 2023 Thank you for the document! I will get under there today and see what it looks like. Link to comment Share on other sites More sharing options...
SpottedJag96 Posted December 3, 2023 Author Share Posted December 3, 2023 Found the problem! One of the leveling rod ends broke. I had the same problem last year with the other side. I know the part is about $5 and should be an easy fix. Thanks for all the help! Link to comment Share on other sites More sharing options...
veraken Posted December 4, 2023 Share Posted December 4, 2023 Just recently had to replace the ride height linkage on my MH. This is what I used. https://www.napaonline.com/en/p/MBI48100367?impressionRank=1 Link to comment Share on other sites More sharing options...
