DennisZ Posted December 15, 2023 Share Posted December 15, 2023 Has anyone installed a storage box in the middle interior entry step? I’ve seen some coaches that have them, just wondered if it’s doable or is it to much of a PITA for the gain. Thanks Dennis Link to comment Share on other sites More sharing options...
Dr4Film Posted December 15, 2023 Share Posted December 15, 2023 One member has done just that recently when he needed access to his hydraulic pump and solenoids. I suggest you do a search for the thread. Link to comment Share on other sites More sharing options...
DennisZ Posted December 15, 2023 Author Share Posted December 15, 2023 Thanks, that was the thread I was looking for. Link to comment Share on other sites More sharing options...
tmw188 Posted December 15, 2023 Share Posted December 15, 2023 I have one in my Windsor, did some come with them? Richard, Jim?? Link to comment Share on other sites More sharing options...
LakeBob Posted December 15, 2023 Share Posted December 15, 2023 Was standard on my 09. Link to comment Share on other sites More sharing options...
Dr4Film Posted December 15, 2023 Share Posted December 15, 2023 Standard on both my Windsor and Dynasty. Link to comment Share on other sites More sharing options...
Tom Whitlow Posted December 16, 2023 Share Posted December 16, 2023 Same here. Standard on my 09. Link to comment Share on other sites More sharing options...
LakeBob Posted December 16, 2023 Share Posted December 16, 2023 I would be interested if anyone has built a replacement box. The plastic rim is breaking up on mine, still functional, however, would be nice to devise a replacement. I have a fairly well stocked shop, however I dont have a metal shear, brake or other equipment to properly form stainless sheets. Would love to make one from stainless. Anyone have any ideas? Thanks! Bob Link to comment Share on other sites More sharing options...
Dr4Film Posted December 16, 2023 Share Posted December 16, 2023 Look for a metal fabricating shop in your area. They would have everything in their shop to build exactly what you are looking for. Use your old plastic one as a model for the new one. Link to comment Share on other sites More sharing options...
tmw188 Posted December 16, 2023 Share Posted December 16, 2023 I’m a retired sheet metal worker & fabricator. I don’t think you need to go with SS. I would consider 26 or no heavier than 24ga galv. Spray the outside with under coating once you know it fits the way you want it. Go to any HVAC shop see if they will make it. I would maybe go with a Pittsburg Lock seam to make it almost water tight except in the corners that the undercoating would seal. DO NOT try to measure to close. Allow for growth tell the shop what you’re trying to make. I would knock off at least3/8” both ways. Good luck. Link to comment Share on other sites More sharing options...
LakeBob Posted December 16, 2023 Share Posted December 16, 2023 Thanks guys, great ideas. I’ll add this to the list for the summer. Im planning on remodeling the entry. Could use some style instead of the black stair treads I have now ! Link to comment Share on other sites More sharing options...
