Just Jim Posted April 9 Share Posted April 9 The lens says SAE U-93, but I can't find anything that looks like it. Anyone have a good source for a replacement? I wired up the front dash switch for the ML ACR and when finished noticed the tail lights on the passenger side did not work. Trial and error and figured out that a ground was faulty. I used spare wires that had previously been used for a brake controller, so I suspect somewhere there is an issue that I didn't have time to run down. I just supplied another good ground and the lights all work again. However, I found during testing that most of the connections are in really bad shape and the bulb sockets are loose, etc. So... long story short... I'm replacing the brake light housing with new LEDs. I am hoping they are an easy change out, but I'm not holding my breath. Anyway, I think I should replace the center brake light as well just for aesthetics. Link to comment Share on other sites More sharing options...
klcdenver Posted April 10 Share Posted April 10 Just measure the light and go to Amazon they have them. I bought one on Amazon several years ago and no problem so far. Link to comment Share on other sites More sharing options...
Just Jim Posted April 10 Author Share Posted April 10 I have looked on Amazon and can't find one that is the correct size. Most are to long. I may just keep what I have. It works. Link to comment Share on other sites More sharing options...
MyronTruex Posted April 10 Share Posted April 10 https://www.amazon.com/gp/product/B019TRZR0W/ref=ox_sc_act_title_1?smid=AWD8UITGYBZKS&psc=1 Link to comment Share on other sites More sharing options...
Just Jim Posted April 10 Author Share Posted April 10 Thanks Myron, that one is about 4 inches to long. There is an indentation on the back of my coach for the light to fit into... have not found one yet that will fit. Link to comment Share on other sites More sharing options...
MyronTruex Posted April 10 Share Posted April 10 There is an indentation on mine as well. It took me a couple of trys to get one to fit. Maybe Supernright lights? Link to comment Share on other sites More sharing options...
cbr046 Posted April 10 Share Posted April 10 Sounds like salvage yard material . . . - bob Link to comment Share on other sites More sharing options...
Paul J A Posted April 10 Share Posted April 10 Have you considered taking the light to NAPA and let them get one. Link to comment Share on other sites More sharing options...
windsorbill06 Posted April 10 Share Posted April 10 (edited) Kaper supplied them for my coach. Here's a link. https://www.kaperii.com/ If you don't have any luck, post the dimensions of yours. Edited April 10 by windsorbill06 1 Link to comment Share on other sites More sharing options...
Frank Bergamo Posted April 10 Share Posted April 10 Try this, they are not an exact fit, have been slightly modified. Spoilerlights.com. Third Brake Light Alternative | Type: SL-84013 Link to comment Share on other sites More sharing options...
