Keith H. Posted June 9 Share Posted June 9 I’ve seen these flat looking pieces of equipment that are attached above the slide-out topper that kinda “sweeps” the material clean of leaves, twigs, thick mud or dirt and other debris as the slide & topper is retracted back in to the coach. It then folds over the slide topper ensemble. It appears to come in aluminum color or black plastic or metal Does anyone know what these are called? TIA Keith Link to comment Share on other sites More sharing options...
Solution tmw188 Posted June 9 Solution Share Posted June 9 (edited) TRUE TOPPER, I think they must cut that top frame off for them to adapt would be my guess. Edited June 9 by tmw188 Link to comment Share on other sites More sharing options...
Ivan K Posted June 9 Share Posted June 9 TimAZ can tell you all about the process first hand. I have seen it on his coach and it looks good. 1 Link to comment Share on other sites More sharing options...
timaz996 Posted June 9 Share Posted June 9 Yes they are called True Toppers. I had my two slides done in OR but they have places in the mid-west that do them also. No I'm not affiliated with them, I just like their product. https://www.truetopperusa.com/truetopper 5 hours ago, tmw188 said: TRUE TOPPER, I think they must cut that top frame off for them to adapt would be my guess. They cut off most of the top Flange and build a ramp behind it. 1 Link to comment Share on other sites More sharing options...
