Blacknight Posted October 6, 2020 Share Posted October 6, 2020 I have a 2007 Knight and the book says to extend the slides and then drop the air in the bags and level the coach. I always use 6x6 blocks under the leveling jacks for support. Why (or what advantages) do you gain by letting the air out of the system. I think being "aired up" would support the slides and maybe not over flex the air bags. What do you do? Link to comment Share on other sites More sharing options...
DavidL Posted October 6, 2020 Share Posted October 6, 2020 The reason to drop the air first is to help ensure that the jacks are extended the minimal amount to level the rig. On mine, the auto level drops the bags, then extends until the system sees pressure on each leg. So it then knows it has touched "ground" (or blocks). I then raises the low side in pairs to keep the chassis from twisting. Link to comment Share on other sites More sharing options...
Steve Hepfer Posted October 6, 2020 Share Posted October 6, 2020 Dumping the air reduces the height of the jacks to level off. On our 2008 Diplomat they say to extend the slides, then dump the air, them level the coach. Make sure you check manufacturer recommended procedures then Link to comment Share on other sites More sharing options...
David Pratt Posted October 6, 2020 Share Posted October 6, 2020 You do not use the same procedure to Level a coach that has Jacks as you would use to level a coach that has Air Leveling only. If your coach is equipped with electric slides the procedures are different than if you have all Hydraulic slides. It is highly recommended that you follow the instructions in your owners manual for your particular coach. Most owners have their own variations of leveling and extending/retracting the slide outs on their particular model coach based on their own experience, but that does not mean it will work for someone else. Following the procedures in the owners manual will keep you out of trouble in most cases. Link to comment Share on other sites More sharing options...
saflyer Posted October 7, 2020 Share Posted October 7, 2020 “It is highly recommended that you follow the instructions in your owners manual foryour particular coach.” Sometimes that can be kind of hard to do when the owner’s manual says different things in different sections. My ‘05 Holiday Rambler manual doesn’t mention dropping the air before leveling in the main section but does tell you to do it in the boondocking section. Link to comment Share on other sites More sharing options...
Jim McGarvie Posted October 7, 2020 Share Posted October 7, 2020 Our coach doesn't give us any choice: When we start the hydraulic leveling jacks down the air is automatically dumped. Link to comment Share on other sites More sharing options...
waterskier_1 Posted October 7, 2020 Share Posted October 7, 2020 Another reason to dump the air, is to have the coach lower to the ground. It will be less susceptible to wind movement, and, more importantly, you won't need a step ladder to get into the coach. I find it amusing to see coaches with additional steps to get to the steps, while the coach is sitting at ride height. Granted, many of those coaches may not have air suspensions (we tend to them for granted) and therefore can't drop the coach lower, but it still looks odd when sitting next to a coach the is kneeling on the ground next to it. Link to comment Share on other sites More sharing options...
