jbb5716 Posted November 5, 2020 Share Posted November 5, 2020 Can anyone tell me the specs for the ATC switch for my 2007 Dynasty Squire. The switch is located on the Driver Side console and has a separate amber LED indicator light. It is a momentary switch and has no ID # that I can find. I checked its operation with an ohm meter. Terminals 7 & 8 appear to be connected in both switch positions which strikes me as odd. Terminals 3 & 4 are open in the normal position and connected when the switch is put in the momentary position. Terminals 7 & 8 are never connected to terminals 3 & 4. Any help is appreciated. John B Link to comment Share on other sites More sharing options...
vito.a Posted November 5, 2020 Share Posted November 5, 2020 (edited) I found replacement Carling switches at Northwest RV Supply. If you don't find your switch listed give them a call. http://www.nwrvsupply.com/category/170.html http://www.nwrvsupply.com/category/177.html http://www.nwrvsupply.com/category/172.html http://www.nwrvsupply.com/category/25-BASE.html Edited November 5, 2020 by vito.a 1 1 Link to comment Share on other sites More sharing options...
jbb5716 Posted November 5, 2020 Author Share Posted November 5, 2020 Thank you. NWRV supply web site does have my switch but does not have the "on-off" specs. According to the Carling web site the V2D1 switch is manufactured to many different internal configurations including what I have. I will call NWRV when they open at 9 PST. Link to comment Share on other sites More sharing options...
Dr4Film Posted November 5, 2020 Share Posted November 5, 2020 What does your existing Carling Technologies switch have for a spec printed on the side of it? How many contact terminals does it have? Carling switches can have up to 8 connection terminals with lamps at each end. Link to comment Share on other sites More sharing options...
jbb5716 Posted November 5, 2020 Author Share Posted November 5, 2020 I found the part # V2D1. It has 4 terminals (2,3,7,8) Grounds are connected to #3 & 7. One of the two wires on #2 goes to the amber LED lamp. Two of the 3 wires on #8 are for the daisy chained switch backlights. Not sure about the third wire. After thinking about it, the fact that 7 & 8 are an "on-on" configuration makes sense to keep the backlights on. I am now assuming that the switch is OK and my problems lie elsewhere. Link to comment Share on other sites More sharing options...
Dr4Film Posted November 5, 2020 Share Posted November 5, 2020 With only 4 terminals being used, two of those are for the back-light when the dash lights are on. The other two are for the momentary switch for the ATC. What are the symptoms for the ATC that you are trying to correct? Link to comment Share on other sites More sharing options...
Dennis H Posted November 5, 2020 Share Posted November 5, 2020 Remember too, the switch numbers are NOT Carling numbers. They are proprietary numbers pertaining to Monaco only. If purchasing them somewhere else, the numbers on the switches are of no use.....Dennis Link to comment Share on other sites More sharing options...
