dkelly Posted December 12, 2020 Share Posted December 12, 2020 I am looking to upgrade the headlight and tail light upgrade on my 2003 Monaco diplomat. I would greatly appreciate assistance on what type lights will work or fit my motorhome. Thanks Darrylk 2003 Diplomat Link to comment Share on other sites More sharing options...
Dennis H Posted December 12, 2020 Share Posted December 12, 2020 First things first. Do you intend to modify your coach or are you looking for something that will fit as a plug and play? There are number embossed on the lenses themselves. Take down those numbers and do an internet search. Once you've determined what Monaco used for your coach, then you can begin your search. For instance, my coach has 2005 Dodge RAM headlamps but a 2004 Lincoln Navigator tail lights. Mine were made by TYC who no longer makes the tail lights meaning I had to use another brand and modify the holes they fit into. The head lights fit perfectly....someone with your year and model might chime in an save you some trouble....Dennis 1 Link to comment Share on other sites More sharing options...
JDCrow Posted April 3, 2021 Share Posted April 3, 2021 E series Ford Van Front. Not much to choose from. Rears are obviously 2 units stacked. I’m in the process of seeing If E series or Ford Excursion taillights will measure to fit. Link to comment Share on other sites More sharing options...
JDCrow Posted April 4, 2021 Share Posted April 4, 2021 Found it! Not sure you have updates clicked to get an email about this. Not cheap, but will be ordering. These fit our coaches https://www.vantageoptics.com/shop/Ford-Econoline-Complete-Headlight-Kits-c25728076 Link to comment Share on other sites More sharing options...
rpasetto Posted April 4, 2021 Share Posted April 4, 2021 Check the Monaco Parts list as well as looking for matches to the DOT number on the lens. Once you have that info check selling sites, local dealers or sellers on the internet may have what you want. Link to comment Share on other sites More sharing options...
FingerTight Posted April 9, 2021 Share Posted April 9, 2021 Hi all! I ordered up a set of stock headlight housings to replace mine (they're yellowed). Anyone taken the headlight housings out? Was assuming I'd just look in from the front and see the mounting screws but not so much. Would love any guidance. Just need to remove and replace. 2002 Diplomat 40DST. Link to comment Share on other sites More sharing options...
wamcneil Posted April 12, 2021 Share Posted April 12, 2021 (edited) Mine has the bmw lights, but I would assume they have similar mountings. Once I crawled up in there the attachments are pretty kludgy, but fairly intuitive. Mine just have some aluminum straps that go around the back of the light and hold it up in the aperture. I wish I had those van lights... I bet they are a much better fit for this application than the bmw housings. Cheers, Walter Edited April 12, 2021 by wamcneil Link to comment Share on other sites More sharing options...
