Weldex screen size
Jeff H
Good Morning All
I have a 2006 Diplomat with, I believe, a Weldex back up camera.  My rig is in storage and not easily accessible and I would like to know what the screen size is on the camera system.  can any one tell me what he width and height are?  I am looking at a new system that comes with a choice of monitor size.
Thank you
My opinion....I would take the time to go and measure mine myself. Relying on someone else as to what they have may produce undesired results. For instance, I measured my OWN Velvac mirror bases and got replacements based on MY measurements. They didn't fit! Why? Because the radius was different! Who would have thought. Anyway, unless you have your build sheet, assuming it's accurate, you'll have your model number and an internet search will give you perhaps the accurate information assuming it was inputted correctly or more correctly described from the foreign interpretation of the spec sheet. There is nothing better than a yardstick in your own hand. It seems like you want to order a new system part for your coach which won't be installed until after the expiration of the return window if it's wrong. I wouldn't want to rely on what someone else has in their coach. Been there done that.....Dennis
Jeff,
I also have a 2006 Dip and had to run check on it today.  Here are pictures and measurements of my Weldex WDRV‐6800M monitor:
5-1/2” tall
6-1/2” wide
7” diagonal screen, 4:3 aspect ratio
hope that helps!
We got rid of the Weldex system years ago because it was so unreliable. Changed to Voyager and mounted the monitor above were the Weldex was using Ram mounts. Removed the old Weldex and covered the hole in the dash with a tablet computer running SilverLeaf.
Jeff,
I replaced my monitor with this one from rvcams.com. Tim is very helpful there. The new monitor is larger than existing and I used velcro Command strips to hold it in place.  That allows me easy access behind it too.  Sorry, no pic on phone.
