bobstromain Posted March 28, 2021 Share Posted March 28, 2021 I have flushed the black water tank, and getting ready to change the dump valve. Are there any do's and don'ts I should know about Bob St. Romain 04 Windsor Link to comment Share on other sites More sharing options...
JDCrow Posted March 28, 2021 Share Posted March 28, 2021 Following this, We have seepage from our valves Link to comment Share on other sites More sharing options...
Jonbrooks Posted March 28, 2021 Share Posted March 28, 2021 On my to do list. Link to comment Share on other sites More sharing options...
Rikadoo Posted March 28, 2021 Share Posted March 28, 2021 When reassembling mine i used som plumber grease on the new seals to help keep them in place. Also to some extra room when removing an installing the black water valve i found it helpfull to loosen the gray water valve. One more thing is to raise that side of coach with levelers so as to avoid any drips coming thru💩 Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted March 28, 2021 Share Posted March 28, 2021 Tilt the coach to the opposite direction which should be the passenger side. That way anything left in the tank will not flow out when you change the valve. Chuck B 2 Link to comment Share on other sites More sharing options...
vanwill52 Posted March 29, 2021 Share Posted March 29, 2021 When I removed my valves to replace them, the piping from either side collapsed inward. It had to be spread apart to get the valve to slide in without disturbing the seals. After several tries, I made a "spreader" from threaded rod and wood to hold it spread apart. Also, on my 2000 Dynasty, pulling either valve to dump the tank put enough strain on the pipes to cause them to move quite a bit. Thinking this might one day become a problem, I added braces to the two valve assemblies to keep them firmly in place. Link to comment Share on other sites More sharing options...
bobstromain Posted March 29, 2021 Author Share Posted March 29, 2021 Thanks for all the comments. It is a very simple job, but I would not say it was easy. May be a good idea to change both valves while you are in to it. Spreading the two lines enough to get the new valve in was the difficult part Thanks again for the support. Don't know how we would make it with out all the knowledge and experience and willingness to help in this group Bob St. Romain 04 Windsor Link to comment Share on other sites More sharing options...
Rick A Posted April 9, 2021 Share Posted April 9, 2021 On 3/28/2021 at 1:00 PM, Chuck B said: Tilt the coach to the opposite direction which should be the passenger side. That way anything left in the tank will not flow out when you change the valve. Chuck B I tilted the coach to the valve. Switched on the tank cleaner, let it drain for a few minutes and then put a bucket under the opening. Either way just make sure you are aware of the possible splash effects! Just now, Rick A said: I tilted the coach to the valve. Switched on the tank cleaner then let it drain for a few minutes and put a bucket under the opening. Either way just make sure you are aware of the possible splash effects! I greased the new valve with vasaline because the instructions recommend this. I also drilled a small hole at the end of the slide on the top so I can squirt vasaline into the slide periodically. I then put a small stainless steel screw in the hole that I drilled. Had the same valve for 6 years. Link to comment Share on other sites More sharing options...
