sunnysadog Posted May 14, 2021 Share Posted May 14, 2021 I have a 2005 Monaco Windsor PDQ. Started getting the coach ready for a trip and plugged in a small portable fan in one of the 120v overhead receptacles. Did not work. So I tried it in every receptacle in the coach. Nothing. All are dead (I did take the fan back into the stick built house, plugged it in and it worked fine). All of the lights in the overhead cabinets and the ceiling are working fine. So I went to the breaker boxes on the back wall. All of the breakers were OK, but I reset them anyway. I pulled each of the small amp fuses and they looked fine. I went to the rear run bay and cycled the house main switch twice. I’m at a loss. Any ideas or suggestions would be greatly appreciated. ArtM 05 Windsor PDQ Link to comment Share on other sites More sharing options...
waterskier_1 Posted May 14, 2021 Share Posted May 14, 2021 Check the circuit breakers on your inverter. Link to comment Share on other sites More sharing options...
jfbolkovatz Posted May 14, 2021 Share Posted May 14, 2021 Check both GFI receptacles they're probably tripped. Link to comment Share on other sites More sharing options...
ncsteve Posted May 14, 2021 Share Posted May 14, 2021 I am sure it is, but is the coach plugged in to 120v. I agree with others breakers on in inverter or ground fault. Link to comment Share on other sites More sharing options...
Dr4Film Posted May 14, 2021 Share Posted May 14, 2021 "All of the lights in the overhead cabinets and the ceiling are working fine." These are all 12 VDC power lights - not 120 VAC where you are having the problem. It is most likely tripped GFI's that need to be reset. 1 Link to comment Share on other sites More sharing options...
John Haggard Posted May 14, 2021 Share Posted May 14, 2021 58 minutes ago, Dr4Film said: "All of the lights in the overhead cabinets and the ceiling are working fine." These are all 12 VDC power lights - not 120 VAC where you are having the problem. It is most likely tripped GFI's that need to be reset. The AC and DC Dilemma Link to comment Share on other sites More sharing options...
sunnysadog Posted May 14, 2021 Author Share Posted May 14, 2021 Problem Solved!! When I've moved the coach this morning, I shut the 50a off at the pedestal and unplugged the coach. After getting it where I wanted it, I plugged it back in and went about my work until my wife told me that there was no power at the receptacles. About 20 minutes ago I decided to start the coach and look at the electrical status on Alladin. "NO AC PRESENT" was the status. Went to the pedestal and found the breaker was still in the off position. I feel very dumb right now. Thanks to those who replied. ArtM 1 1 Link to comment Share on other sites More sharing options...
Dr4Film Posted May 14, 2021 Share Posted May 14, 2021 7 minutes ago, sunnysadog said: Problem Solved!! I feel very dumb right now. ArtM Link to comment Share on other sites More sharing options...
Harvey Babb Posted May 14, 2021 Share Posted May 14, 2021 Rest assured that you are the only one on this group who has ever done anything like that! NOT! If that is the worst mistake you ever make you will be doing extremely well my friend! 1 1 Link to comment Share on other sites More sharing options...
John Haggard Posted May 14, 2021 Share Posted May 14, 2021 15 minutes ago, Harvey Babb said: Rest assured that you are the only one on this group who has ever done anything like that! NOT! If that is the worst mistake you ever make you will be doing extremely well my friend! Fortunately we had airstream trailers from the 60s to the early 90s Then diesel pushers All AC, DC power wired. It is a learning curve and if you don't use your rig or trailer consistently one can forget or get somewhat confused 😐🤔 Our houseboat has a AC and DC bulb in every ceiling fixture wired specially. No shore power No generator running We use the DC switch When on shore power or the generator is running We use the AC switch, bulb 💡 When guests are visiting 😍 It's common to find both on at the same time. Link to comment Share on other sites More sharing options...
