Darren A. Posted June 9, 2021 Share Posted June 9, 2021 This morning getting ready to venture out my driver side front slide would not retract in. The hydraulic pump has good tone and the other three slides worked perfectly fine. Finally while depressing the switch for about 15 seconds the slide retracted in. I also notice a delay extending the slide the other day. Perhaps a hydraulic leak somewhere or something else? Link to comment Share on other sites More sharing options...
Rikadoo Posted June 9, 2021 Share Posted June 9, 2021 So electro hydraulic solinoids can fail in many ways, first i would test to ensure you have a solid power an ground at the solinoid that controls hydraulics to the rams. Especially if this has been getting more an more slugish Link to comment Share on other sites More sharing options...
Darren A. Posted June 9, 2021 Author Share Posted June 9, 2021 I will check the solenoid as you suggest, but if fine what would be the next process of elimination? I failed to state this is for 2004 Holiday Rambler Navigator. Link to comment Share on other sites More sharing options...
Rikadoo Posted June 10, 2021 Share Posted June 10, 2021 Hydrolics are not to difficult, first i would suggest checking the fluid level, you said the pump sounded like it has a good tone, is that before the slide moves or as it is moving. When it starts to move is the slide movement jittery or smooth? On my stabilizers there are quick disconnect plugs for the solinoid pack, when i was installing my FASS fuel system i saw where the connector had green corrosion coming from it so i cleaned it all up an now the whole system is a lot more responsive where as there were times i would have to switch it on an off a couple times before it would respond to commands. After cleaning the terminils i used dielectric on all the terminils Link to comment Share on other sites More sharing options...
Darren A. Posted June 10, 2021 Author Share Posted June 10, 2021 The tone was good before and while the slide finally moved. It moved smoothly. The end of season last year I changed and replaced the hydraulic filter and fluid, inside the rear aluminum tank engine compartment? Is that where the slides draw fluid from or just from the hydraulic pump and tank in generator slide out in front of the Coach? Link to comment Share on other sites More sharing options...
Rikadoo Posted June 10, 2021 Share Posted June 10, 2021 Ok so your pump is running... (hopefully the tank is full of oil) the next thing is the pressure regulator is off its seat, either dirt between the seat an ball or damaged spring. Your going to need to disassemble the regulator an check it for ??? Dirt, damage if its ok i would swap a known good operating solinoid with the one thats not working. I would connect a high pressure gauge to one of the hoses an check the pressures 1st just to ensure you dont have a issue with the slide. Your going to have to connect to a slide that is working to know what your operating pressure is supposed to be. Link to comment Share on other sites More sharing options...
David Pratt Posted June 10, 2021 Share Posted June 10, 2021 Darren, The Hydraulic motor and Hydraulic Reservoir Tank and Solenoids are one unit and in your coach will be located under the Entry Step. To access the pump and reservoir assembly you have to lift the step cover and remove the cover/storage in the step. There is a fill cap on the reservoir. Check the fluid level with all the slides in. If you are having and issue with only one slide then more than likely one of the solenoids has failed or is failing. There is no pressure regulator in the HWH system, all slide-outs are controlled by the solenoids, there is a high pressure switch that locks the slide out in with hydraulic pressure. The solenoids are easy to change, it is just difficult because of the location of the hydraulic pump assembly. Your HWH Operating Manual has a trouble shooting section and also shows you how to replace the solenoids. If you do not have a Manual you can download one off the Internet or we may have the Manual in our files. 1 Link to comment Share on other sites More sharing options...
Darren A. Posted June 11, 2021 Author Share Posted June 11, 2021 Thank you all for responding, will attempt suggestions and will update everyone. Link to comment Share on other sites More sharing options...
Darren A. Posted August 7, 2021 Author Share Posted August 7, 2021 Update on my slide situation. After a long wait to get the Coach serviced and waiting for the part David you were 100% correct Hydraulic Reservoir located underneath entry step. The Solenoid for the driver side front slide was replaced and everything back working. Thank you all for responding to my question on June 9th. The part number# RAP42632 I intend on buying a few to keep on hand and if necessary will replace them myself in the future. Link to comment Share on other sites More sharing options...
Darren A. Posted August 17, 2021 Author Share Posted August 17, 2021 Sadly I spoke to soon the slide out will not retract back in normally. They put this solenoid on the slide extended no problem but again took me several attempts holding the switch to get it back in. Could someone give me direction what to check next Link to comment Share on other sites More sharing options...
Ivan K Posted August 17, 2021 Share Posted August 17, 2021 When you say that it takes several attempts, does it mean that it slows down until you do it again or does it just cut the pump off? Link to comment Share on other sites More sharing options...
Darren A. Posted August 18, 2021 Author Share Posted August 18, 2021 I hold the switch down for no more than 10 seconds each time the pump runs, then by the 4th or 6th attempt it comes in no delay. Link to comment Share on other sites More sharing options...
David Pratt Posted August 18, 2021 Share Posted August 18, 2021 The other solenoid is failing and will need to be replaced. Sometimes it is best to replace both solenoids for any particular slide when they start acting up like you describe. Replace the solenoid and purchase a spare to have when another one fails. 1 Link to comment Share on other sites More sharing options...
Darren A. Posted August 18, 2021 Author Share Posted August 18, 2021 Thank you David, I asked the service technician whether both should be replaced and of course he said no. I will be purchasing more solenoid and putting them on myself its appears to be pretty straight forward. Thank you so much for your input. Link to comment Share on other sites More sharing options...
