Rikadoo Posted June 13, 2021 Share Posted June 13, 2021 So i was taking The RV back to storage and I had to do a couple forward backward maneuvers and I noticed when I pushed Drive I would get a clunk coming out of the back end of the coach I have a diesel pusher and I noted that it did not do it in reverse only and drive it didn’t matter if the brakes were on or off, of course the engine is ideling an vehice is not moving when changing direction. I havent noticed this until this last trip to the storge lot. A day before i just lubed the entire suspension an drive line. It may be nothing, i may still be in sticker shock after having just replaced the radiator an water pump. The rig drives an shifts great, last year i replaced the trans filters an fluid an compleated a 1800 mile trip with no problem, when i got parked i ran the fluid check an it past with “ok”... any thoughts Link to comment Share on other sites More sharing options...
klcdenver Posted June 13, 2021 Share Posted June 13, 2021 20 minutes ago, Rikadoo said: So i was taking The RV back to storage and I had to do a couple forward backward maneuvers and I noticed when I pushed Drive I would get a clunk coming out of the back end of the coach I have a diesel pusher and I noted that it did not do it in reverse only and drive it didn’t matter if the brakes were on or off, of course the engine is ideling an vehice is not moving when changing direction. I havent noticed this until this last trip to the storge lot. A day before i just lubed the entire suspension an drive line. It may be nothing, i may still be in sticker shock after having just replaced the radiator an water pump. The rig drives an shifts great, last year i replaced the trans filters an fluid an compleated a 1800 mile trip with no problem, when i got parked i ran the fluid check an it past with “ok”... any thoughts Check your U Joints. 2 Link to comment Share on other sites More sharing options...
Ivan K Posted June 13, 2021 Share Posted June 13, 2021 If it is a new clunk, check the ujoints. There should be no play in ujoints. Some, very little free movement in the rear end gear is normal but you say it is a new sound so it should be investigated as where exactly it is coming from. 1 Link to comment Share on other sites More sharing options...
PeterSchweizer Posted June 13, 2021 Share Posted June 13, 2021 10 minutes ago, klcdenver said: Check your U Joints. Mine will do that too if I go from R to D. Nut if I go to N first it does not. Try that it's an RV dont rush! 1 1 Link to comment Share on other sites More sharing options...
