Guest Steven Posted September 4, 2021 Share Posted September 4, 2021 I woke up this morning to no power in motorhome. Have power at post. Checked breakers and all good. Smart EMS shows no incoming power. Any suggestions? Possibly transfer switch? Would like to check but do not know the location. Is there a reset on transfer switch? Steve 2004 Windsor 40 DST. Link to comment Share on other sites More sharing options...
Just Jim Posted September 4, 2021 Share Posted September 4, 2021 much more info needed. Do you have an 12v power? Do you have power unplugged from post? Do you have power with Genset on? Link to comment Share on other sites More sharing options...
Dr4Film Posted September 4, 2021 Share Posted September 4, 2021 Are we talking 120 VAC power or 12 VDC Power? Link to comment Share on other sites More sharing options...
Dwight Lindsey Posted September 4, 2021 Share Posted September 4, 2021 Steve: The transfer switch will be near the place where the shore power cable enters the motorhome. Probably in a rear compartment. Someone with a 2004 Windsor could guide you more specifically. There is not typically a reset switch on a transfer switch. That said, I don't know which transfer switch you have. If you haven't yet, you should certainly check and re-set all of the breakers in your breaker box. Unless you're VERY comfortable with electrical work, I suggest great caution about opening the transfer switch to check it. All power sources must be off, battery disconnects disconnected and shore power disconnected. Dwight Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted September 4, 2021 Share Posted September 4, 2021 Steve, Your transfer switch is located in the narrow bay foward from the bay where your dump valves are located. Your PTS is a Esco brand switch. Send me A PM to jbee99807@gmail.com and I will send you a picture. Chuck B 2004 Windsor 1 Link to comment Share on other sites More sharing options...
waterskier_1 Posted September 4, 2021 Share Posted September 4, 2021 Generally, the Smart EMS is installed between the power post and the transfer switch. If it shows no power, then the transfer switch isn't likely the problem. You either are not getting power to the EMS, (power at the pedestal, connection on the cable, cable itself, etc.) or the EMS itself had shut shown the power. Link to comment Share on other sites More sharing options...
Guest Steven Posted September 4, 2021 Share Posted September 4, 2021 If the EMS has shut down the power, is there a way to restore or reset it? Link to comment Share on other sites More sharing options...
vito.a Posted September 4, 2021 Share Posted September 4, 2021 Steven, you probably should start your own thread. Monaco used Sanden A/C compressors on Cummins engines. For what its worth ours is a Sanden U4756. Also, check your coach model number as Monaco did not manufacture a 42' Windsor. If you have the Monaco recreational vehicle data card it will list you compressor model number. Link to comment Share on other sites More sharing options...
Scotty Hutto Posted September 4, 2021 Share Posted September 4, 2021 Steve, Reach out to Chuck B (above). He’s the resident expert on Windsors! Link to comment Share on other sites More sharing options...
jacwjames Posted September 4, 2021 Share Posted September 4, 2021 Is the "Smart" EMS you are talking about the load shedding system? Do you have any type of surge protector. First thing I'd do is fire up the Generator, if you get power to the coach at least you know that side is working. Link to comment Share on other sites More sharing options...
waterskier_1 Posted September 4, 2021 Share Posted September 4, 2021 2 hours ago, Steven said: If the EMS has shut down the power, is there a way to restore or reset it? If you are talking the Smart EMS Surge Protector (like a Progressive EMS) that should be located near the transfer switch. I don't think that Windsor's had a load shedding EMS which would shed loads on 30 Amp Service. If the Smart EMS Surge Protector shut down it's because the incoming voltage is outside of parameters (too high, too low, bad neutral, etc.) and self-checks for the condition to come back into tolerance for a few minutes and then clears itself and passes the good power on to the transfer switch. There is nothing you have to do to clear it, other than maybe call the park and tell them their power is out of tolerance. It would be good to check that you have power into that EMS and then none out of the EMS, and check the voltages on both legs where it comes into the EMS. If the voltages are good, possibly your EMS is bad. But check to make sure the incoming power is good before you replace it. Since all was good last night, it's most likely the Park has a problem, but you can check that at the pedestal. Link to comment Share on other sites More sharing options...
Dr4Film Posted September 4, 2021 Share Posted September 4, 2021 (edited) Rick, Windsor's did come with the Intellitec EMS Load Shedding System, at least mine did. However, people when posting need to identify what they are referring to. Whether they have some sort of EMS system (aka Progressive Industries or Southwire or Hughes Power Watchdog which are three suppliers that come to mind) that monitors the incoming power to their coach which is generally installed prior to the transfer switch OR are they posting in regards to the Intellitec EMS Load Shedding System. Edited September 4, 2021 by Dr4Film 1 1 Link to comment Share on other sites More sharing options...
David Pratt Posted September 5, 2021 Share Posted September 5, 2021 you need to identify what Model Transfer Switch your coach has. Link to comment Share on other sites More sharing options...
