Steve P Posted September 10, 2021 Share Posted September 10, 2021 Back right hatch, below the oil and transmission fills, and purge tank. What is it? Link to comment Share on other sites More sharing options...
Ivylog Posted September 10, 2021 Share Posted September 10, 2021 Hydraulic reservoir 1 Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted September 10, 2021 Share Posted September 10, 2021 Hydraulic fluid filter reservoir. There are 3 filters in the reservoir. They need to be replaced annually to keep the fluid filtered. Chuck B 2004 Windsor Link to comment Share on other sites More sharing options...
Gospel Posted September 10, 2021 Share Posted September 10, 2021 I'm assuming the black cannister is what you are referring to, does it have 3 filters in it, if so do you have the filter #'s. I just bought a 2008 M Knight and I know they did not change anything in this reservoir. Link to comment Share on other sites More sharing options...
Steve P Posted September 11, 2021 Author Share Posted September 11, 2021 56 minutes ago, Gospel said: I'm assuming the black cannister is what you are referring to, does it have 3 filters in it, if so do you have the filter #'s. I just bought a 2008 M Knight and I know they did not change anything in this reservoir. I doubt mine have ever been changed either. I don't know if this is the hydraulic fluid reservoir for the Jack's, or for the the large slide. Any ideas? Link to comment Share on other sites More sharing options...
Ivan K Posted September 11, 2021 Share Posted September 11, 2021 It's for your power steering and if you had a side radiator, for the fan(s). Link to comment Share on other sites More sharing options...
Rikadoo Posted September 12, 2021 Share Posted September 12, 2021 My rig is a 2003 Holiday Rambler, the one i removed was one mfg &#, the one i purchased was supposed to be the replacement, my owner manual gave a different PN Power steering filter: Removed filter Nelson 84365 Installed filter, Baldwin PT 903 Recommended in owners manual: Nelson 83213D or 910048A Link to comment Share on other sites More sharing options...
