JM1998 Posted December 1, 2021 Share Posted December 1, 2021 1998 Monaco Dynasty / diesel Can anyone tell me if this vacuum switch is available? If not, options? Thank for any help Link to comment Share on other sites More sharing options...
Ivan K Posted December 1, 2021 Share Posted December 1, 2021 It is your vacuum generator. Not much can go wrong with it but you can replace it with electric vacuum pump, google will show you the available kinds for other vehicles. Depending what's wrong with it, it should be fixable if the coil works. The plastic check valve looks like one from early C3 and older Vette and is available. Link to comment Share on other sites More sharing options...
JM1998 Posted December 1, 2021 Author Share Posted December 1, 2021 It was clicking constantly while AC was on. That quit and now it stays on defrost. Link to comment Share on other sites More sharing options...
Ivan K Posted December 1, 2021 Share Posted December 1, 2021 I'd say the question is whether it quit generating vacuum or if there is a leak in the vacuum distribution system past the pump. Clicking of the black valve would indicate that it was working but the vacuum was quickly depleted further up due to a leak that might have gotten worse. Link to comment Share on other sites More sharing options...
JM1998 Posted December 1, 2021 Author Share Posted December 1, 2021 Thx. I’ve got some homework to do. Link to comment Share on other sites More sharing options...
MDMiller3 Posted December 1, 2021 Share Posted December 1, 2021 I have the same part in my 2005 Holiday Rambler Navigator and it constantly pushing out air from the discharge valve underneath. The mechanic told me it was a Tag axle dump valve. Is this true? Is there a part number or replacement part for this. Link to comment Share on other sites More sharing options...
JM1998 Posted December 1, 2021 Author Share Posted December 1, 2021 I have no tag axle. No clue Link to comment Share on other sites More sharing options...
Ivan K Posted December 2, 2021 Share Posted December 2, 2021 This has nothing to do with a tag axle or any other axle. The compressed coach air flow creates vacuum via venturi effect, the vacuum is stored in the ball like container and used to operate your dash actuators to route air where you want it. That black valve with solenoid is supposed to close once enough vacuum is stored. Link to comment Share on other sites More sharing options...
JM1998 Posted December 2, 2021 Author Share Posted December 2, 2021 Right on! Is vacuum valve or switch available? Link to comment Share on other sites More sharing options...
Ivan K Posted December 2, 2021 Share Posted December 2, 2021 I never need to replace it or any parts of it but a quick look at our Parts List, pg. 52 shows some alternatives if it in fact is a culprit. I suppose the main valve could be replaced by a simple MAC valve if it was price wise effective. Link to comment Share on other sites More sharing options...
JM1998 Posted December 2, 2021 Author Share Posted December 2, 2021 Please detail. Part number, etc Link to comment Share on other sites More sharing options...
Ivan K Posted December 2, 2021 Share Posted December 2, 2021 17 minutes ago, JM1998 said: Please detail. Part number, etc For the valve? Something like this should work just fine but you would have to confirm the port opening sizes, eventhough I think they are right. Assuming you know for fact that this is what failed. Link to comment Share on other sites More sharing options...
Jimmer Posted December 2, 2021 Share Posted December 2, 2021 On my 03 Windsor the vac pump, that operates the dash HVAC system, ran continueosly . Vac motor switch malfunctioned. Replaced whole unit. It is used on Fords with diesels engine. My part number E3HT-2A451-BA on ebay . Yours looks a little different from mine so check it out before ordering. Link to comment Share on other sites More sharing options...
Dr4Film Posted December 2, 2021 Share Posted December 2, 2021 NAPA carries electric vacuum generators. Take that one to the store and they will match it up for you. Link to comment Share on other sites More sharing options...
Grampy OG Posted December 2, 2021 Share Posted December 2, 2021 On my similar setup I searched high and low for the electric solenoid which had failed in my system. Nothing seemed quite right. Lo and behold I found out quite accidentally that the solenoid switch was an off the shelf item and direct screw in replacement. The part was an electric solenoid from the garden department at Home Depot. The same solenoid used in just about every yard that has automatic sprinklers. Used to turn the zone valves on and off. Changed mine 3 years ago for about $10 and all is still humming along. Good luck Ken Link to comment Share on other sites More sharing options...
