RustyH Posted December 18, 2021 Share Posted December 18, 2021 I recently purchaced 2004 Diplomat and the floor had rotted out by the door, I originally thought the A/C condenser drain was stopped up but I noticed there is a vacuum valve on the drain line and was wondering if it was not functioning, does anyone know how to function test the valve, Thanks Link to comment Share on other sites More sharing options...
Jdw12345 Posted December 18, 2021 Share Posted December 18, 2021 (edited) Deleted Edited December 18, 2021 by Jdw12345 Link to comment Share on other sites More sharing options...
Ivan K Posted December 18, 2021 Share Posted December 18, 2021 I see what probably is the drain hose on the left of the door actuator. These two should have no physical connection. I would try to blow the hose with low pressure from the bottom open end and it should be open or it needs to be cleared. Hopefully without opening the box. Looks like a lot of foam up there, could the expansion possibly pinch the hose if it is soft. Link to comment Share on other sites More sharing options...
Gary Cole Posted December 18, 2021 Share Posted December 18, 2021 Wonder if vacuuming might not be a better option so as not to blow crud back into the drain pan? Link to comment Share on other sites More sharing options...
Ivan K Posted December 18, 2021 Share Posted December 18, 2021 13 minutes ago, Gary Cole said: Wonder if vacuuming might not be a better option so as not to blow crud back into the drain pan? Yes, good advice if vacuum source available and if you can tell that the hose is clear by doing that. Link to comment Share on other sites More sharing options...
Ray Davis Posted December 18, 2021 Share Posted December 18, 2021 What I see is a vacuum hose going to a vacuum actuator. That actuator opens & closes the fresh air door. AFAIK there is no vacuum attached to the drain. You could have a stopped up a/c drain or a leaking heater core. Or maybe a windshield or door leak. I'm betting on the drain or heater core. 1 Link to comment Share on other sites More sharing options...
Gary M Posted December 18, 2021 Share Posted December 18, 2021 My coach had moisture there also but the leak came from the roof down inside the wall. Link to comment Share on other sites More sharing options...
bobdinsmore Posted December 18, 2021 Share Posted December 18, 2021 I have a 2000 Diplomat and also had the carpet getting wet in that same area, but only the rug. It turned out condensation was running down AC/heater box. I removed it and inserted a thin sheet of insulation between the box and the firewall. This fixed the problem. Link to comment Share on other sites More sharing options...
