1nolaguy Posted December 18, 2021 Share Posted December 18, 2021 This probably should be under electronics or electrical but I did not see a field that really applied. A section of the dash in our 2005 Safari Cheetah that houses the radio, dash HVAC, and two 12v (cig. lighter style) outlets has stopped working. I have no 12v power at anything in section of the dash. Everything else on the dash area works. I have checked all the fuses is the compartment below the drivers window and in the house 12v system and all are good. I suspected perhaps a break in the ground but do not get a voltage reading even when going directly to the chassis for ground. Is it possible that every thing in this area (panel above center cup holders and draw) is tied to one 12v source/ fused line with an in line fuse? Any suggestions are appreciated. Link to comment Share on other sites More sharing options...
Old Dog Posted December 18, 2021 Share Posted December 18, 2021 Sounds more like a plug issue where one pin supplies power to the entire area. Do you have elec prints to see what the common denominator is. Link to comment Share on other sites More sharing options...
bunlacken Posted December 18, 2021 Share Posted December 18, 2021 Unusual for the cig lighter not to be on separate fuse, probably 15a Bad ground could take all out. Use a temp jumper ground to test Link to comment Share on other sites More sharing options...
Ivylog Posted December 18, 2021 Share Posted December 18, 2021 27 minutes ago, 1nolaguy said: do not get a voltage reading even when going directly to the chassis for ground. Rules out a bad ground. There may be a inline fuse… Good Luck finding it. Link to comment Share on other sites More sharing options...
1nolaguy Posted December 18, 2021 Author Share Posted December 18, 2021 29 minutes ago, Old Dog said: Sounds more like a plug issue where one pin supplies power to the entire area. Do you have elec prints to see what the common denominator is. Unfortunately I do no have a dash electrical schematic. If anyone has on for same or similar 2005 I would greatly appreciate a pdf or a post here. Link to comment Share on other sites More sharing options...
Seward G Posted December 18, 2021 Share Posted December 18, 2021 There is an extensive collection of wiring diagrams in the "downloads" section of "Bill D's Monacoers" for the 2007 Diplomat. Another person posted that other years and brands are much the same. I looked at the diagrams and saw references to the Cheetah brand. The items you mentioned not working are on different circuits, as I read the diagrams. Maybe something there would be of help. Link to comment Share on other sites More sharing options...
Susan Hill Posted December 18, 2021 Share Posted December 18, 2021 3 hours ago, 1nolaguy said: This probably should be under electronics or electrical but I did not see a field that really applied. A section of the dash in our 2005 Safari Cheetah that houses the radio, dash HVAC, and two 12v (cig. lighter style) outlets has stopped working. I have no 12v power at anything in section of the dash. Everything else on the dash area works. I have checked all the fuses is the compartment below the drivers window and in the house 12v system and all are good. I suspected perhaps a break in the ground but do not get a voltage reading even when going directly to the chassis for ground. Is it possible that every thing in this area (panel above center cup holders and draw) is tied to one 12v source/ fused line with an in line fuse? Any suggestions are appreciated. I've got the same problem in my 2004 Lapalama 37 pst. Very frustrating! Link to comment Share on other sites More sharing options...
1nolaguy Posted December 18, 2021 Author Share Posted December 18, 2021 Thanks Stewart D, I will check that out. Susan Hill, when I find a solution I will post it here. Link to comment Share on other sites More sharing options...
Susan Hill Posted December 18, 2021 Share Posted December 18, 2021 Ditto here Link to comment Share on other sites More sharing options...
