Corkman Posted January 31, 2022 Share Posted January 31, 2022 Replacing the air bags in an RV Because of aging and cracks, I decided to (try) to replace my air bags. I replaced 5 of my 10 air bags on my 2001 Monaco Dynasty 40 Queen (10 air bags because I have a tag axle) the past couple weeks (had to work around my son’s schedule). Here are some take-a-ways: 1. I chose to remove the wheels to gain better access to the air bags. To do this you will need a 1-inch impact wrench in order to get the lug nuts off of the wheels. Nothing smaller even comes close to moving the lug nuts. 2. You will need a big jack to lift the RV. I used a couple 20 ton jacks I already had and they did the job fine. 3. I used one jack under the axle and one between the two frame supports (to raise and lower the frame to gain better access to the air bags to get them in, and out. 4. I would replace the air line 90-degree connectors with ones that are 90-degree but also swivel, it will make it so much easier to re-install. 5. In the rear, the rear air bag was not too bad to gain access to, the other rear (front) was a bear because all the nuts are behind the frame supports. You have to rear around the frame parts to feel for everything and trying to turn wrenches is very hard. 6. After looking at the tag axle air bags I decided they were both in the “too hard” category. Not only do you have to get up inside the transmission cage, but the air bags are up high and the nuts are behind a support beam. I will carry a couple spare air bags and if, in the future, I have an issue with them I will let someone else replace them. 7. In the front I replaced the drivers front air bag. After looking at the drivers front (but rear) and both passenger’s side air bags I decided they are all in the “too hard” category. And, like I said about the tag axle air bags, I decided if I have an issue, I’ll let someone else replace them. 8. While under the coach I looked for air leaks but did not locate any, although I do lose pressure in the air system over night (or at least my dash air gauges go to zero overnight). 9. It took about 4-5 hours for my son and I to replace just 2 rear air bags. 10. I also replaced my air dryer filter located in the rear driver’s side up high behind the rear tag axle. 11. I tried to remember to take pictures and will post any that I think that add value. 12. Feel free to ask questions. Bill 2 Link to comment Share on other sites More sharing options...
klcdenver Posted January 31, 2022 Share Posted January 31, 2022 Thanks. Great info and pics are worth a thousand words. Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted January 31, 2022 Share Posted January 31, 2022 Just asking. The jack under the axle is carrying the total weight of the MH? Gary 05 AMB DST Link to comment Share on other sites More sharing options...
Corkman Posted January 31, 2022 Author Share Posted January 31, 2022 It probably could, it’s rated at 20 tons but it’s actually only carrying half of the rear frame (or less) Link to comment Share on other sites More sharing options...
dl_racing427 Posted February 1, 2022 Share Posted February 1, 2022 I do hope you're using properly rated jack stands in conjunction with the jacks. NEVER rely on a jack alone to support a vehicle when working underneath. Good luck, and be safe. 🙏 1 Link to comment Share on other sites More sharing options...
redstickbill Posted February 1, 2022 Share Posted February 1, 2022 Patrick, Where did you purchase the air bags from and what was the delivery time, please? Bill B 07 Dynasty Link to comment Share on other sites More sharing options...
Robert92867 Posted February 1, 2022 Share Posted February 1, 2022 I have used a Torque Multiplier many times to pull my wheels. Not fast like an impact, but portable enough to carry in my tool kit. Are those the original shocks? Link to comment Share on other sites More sharing options...
Corkman Posted February 1, 2022 Author Share Posted February 1, 2022 6 hours ago, redstickbill said: Patrick, Where did you purchase the air bags from and what was the delivery time, please? Bill B 07 Dynasty I mentioned this in another post 🙂 https://www.finditparts.com/ Only took about 5 days to get Link to comment Share on other sites More sharing options...
