sg47619 Posted April 19 Share Posted April 19 Can’t get power to this under the sink. Single wall plug. Anyone out there had any dealings with one of these Link to comment Share on other sites More sharing options...
Dr4Film Posted April 19 Share Posted April 19 (edited) Do you have a switch labeled Insta-Hot that you may have to switch on to get power to the device? That's the way they wired it in my Dynasty. Should be in the kitchen area. Edited April 20 by Dr4Film Link to comment Share on other sites More sharing options...
SigPIlot Posted April 19 Share Posted April 19 As noted above, there may be a switch on the facia in front of the sink. Easy to turn off thinking its a light switch. I have a box on the wall plug the insta hot is plugged into. I believe it a surge protector. Mine has a green light on the front - indicating power on. Other than checking the breaker for galley/kitchen plugs not much else to check. I find a simple non contact voltage tester (Lowes - Southwire $15) is infinitely useful around the coach for chasing down some electrical issues. Link to comment Share on other sites More sharing options...
Dr4Film Posted April 19 Share Posted April 19 I have a Sperry Instruments combo unit which checks the outlet for proper wiring, tests for proper GFI and also for any "hot skin" condition. Amazon - $22 - https://tinyurl.com/yt8jj437 Link to comment Share on other sites More sharing options...
RVhorod Posted April 19 Share Posted April 19 My switch is located on the side of the sink cabinet. Link to comment Share on other sites More sharing options...
Ivan K Posted April 19 Share Posted April 19 On ours, the 12v switch under counter only operates a relay in a 4x4 box that supplies the 110V to the InstaHot receptacle. So there is a couple points of possible failure. Link to comment Share on other sites More sharing options...
sg47619 Posted April 20 Author Share Posted April 20 10 hours ago, Dr4Film said: Do you have a switch labeled Insta-Hot that you may have to switch on to get power to the device? That's the way the wired it in my Dynasty. Should be in the kitchen area. Thanks I’ll look tomorrow Link to comment Share on other sites More sharing options...
Yoaks5 Posted April 20 Share Posted April 20 My last coach had one of these. It didn't work when I got the coach and if I remember correctly there was a reset button on it. I had to take the metal cover off and it was under there. Link to comment Share on other sites More sharing options...
sg47619 Posted April 20 Author Share Posted April 20 1 hour ago, Yoaks5 said: My last coach had one of these. It didn't work when I got the coach and if I remember correctly there was a reset button on it. I had to take the metal cover off and it was under there. I don’t think I will ever use it just checking things as I get to them. Link to comment Share on other sites More sharing options...
Grampy OG Posted April 21 Share Posted April 21 Mine definitely goes to a SINGLE circuit breaker in the panel. It draws 15 amps when on. I removed the glorified tea maker from two of my coaches and use the dedicated plug to power my remote sub-woofer. Good luck, Ken Link to comment Share on other sites More sharing options...
sg47619 Posted April 21 Author Share Posted April 21 55 minutes ago, Grampy OG said: Mine definitely goes to a SINGLE circuit breaker in the panel. It draws 15 amps when on. I removed the glorified tea maker from two of my coaches and use the dedicated plug to power my remote sub-woofer. Good luck, Ken Yeah my BOSE system won’t work either, I’ll probably just do away with the hot water faucet. Thanks. Link to comment Share on other sites More sharing options...
