Exekia Posted May 23, 2022 Share Posted May 23, 2022 Hi All, I de-winterized today, and behold clearly did not winterize well, despite pushing air a 45psi till all faucets came out with air only. Water filter under sink had burst and several of the Manabloc valves (or the manifold itself is leaking). Looked up videos on Youtube and it seems the valve spindle is pretty easy to replace, but wanted some advice based on what you see in the pic - seems it could very well be valve seals / rings but want to be sure it isn't a cracked manifold post valve. There is a drip coming from the third one p on the right, but all three bottom ones on the right spew when opened and the 2nd up on the left also spews in a similar fashion. All advice appreciated. 2007 Beaver Marquis. Thanks. Anand Link to comment Share on other sites More sharing options...
Smillar99 Posted May 23, 2022 Share Posted May 23, 2022 We had a dripping valve so replaced the valve and seal. Turns out we had a hairline crack in the valve post so we had to replace the manifold. Link to comment Share on other sites More sharing options...
Frank Bergamo Posted May 23, 2022 Share Posted May 23, 2022 I would also be concerned about the Aqua Hot internal loop. Air alone will not winterize your coach. You must pump RV antifreeze through system to insure no freeze damage. Could be an expensive lesson, good luck. Link to comment Share on other sites More sharing options...
DavidL Posted May 23, 2022 Share Posted May 23, 2022 Yup, antifreeze. I do air, then antifreeze. Only way to be sure all low points are protected. Link to comment Share on other sites More sharing options...
Exekia Posted May 23, 2022 Author Share Posted May 23, 2022 Frank - I did pump RV antifreeze through the hot side - I did follow someone's instructions. Air through the cold side, rv antifreeze through the hot side, and antifreeze in all of the p-traps. Thought I had it right. Didn't rush, ran about 5 gal of antifreeze. 🙂 Still looking like an expensive lesson. The Aquhot fired up fine and the hot side of all of the pipes seemed to work fine. No leaks I could see or hear or from the AH. Anyone know if there is a 14 port manabloc available that has the 7 cold 7 hot? and oriented with the cold on the left (though I'm guessing that is reversible). Keep finding 8 cold 6 hot. Anand I do think the bottom of the manibloc ends up being lowpoints. I drained all the low and left them open as I aired... next time I'll antifreeze both sides. Link to comment Share on other sites More sharing options...
Dr4Film Posted May 23, 2022 Share Posted May 23, 2022 What size Manobloc piping are you looking for to replace what you have for input and output pipe sizes? Link to comment Share on other sites More sharing options...
anand.s Posted May 23, 2022 Share Posted May 23, 2022 They look like 1/2” out. The input seems standard. There is a 12 port available that is 6 cold 6 hot, I could just combine two lines. Not sure what to to do with the drain, just keep it capped I’d think. Going to try to replace the spindle valves first. Let’s see how that goes. Link to comment Share on other sites More sharing options...
Just Jim Posted May 23, 2022 Share Posted May 23, 2022 I liked the idea of the Manabloc system, but in reality I never used it. When mine failed I just replaced it with a copper fitting tree. No issues since. Link to comment Share on other sites More sharing options...
Our Escape Posted May 24, 2022 Share Posted May 24, 2022 Not sure if the Manabloc used on a 98 Monaco Windsor is the same, but I had a burst manabloc & leaks everywhere. I ordered a new manabloc from Supply House cut out the old block and mount only to recognize the fittings and pipe sizes were different In name they were the same but just would not fit the old plumbing. I ended up replacing all plumbing (and fixtures) with new pex (blue and red Home Depot & Lowes) I used crimp and stayed away from sharkbite fittings. While I was in the wet bay I gutted it. Replaced all panels with polyethylene sheets cut to size, added lines for an outdoor shower, macerator, heaters for the 3 tanks and insulated the entire plumbing system. Hope this helps. Tom 97 Windsor 1 Link to comment Share on other sites More sharing options...
Dr4Film Posted May 24, 2022 Share Posted May 24, 2022 The 14 port Manobloc Model MXBD1B-14C2 is no longer in production. Your best plan would be to purchase the next size larger, an 18 port, then use the 14 and leave the others turned off. Viega 49183 ManaBloc 18-Port 1/2" Poly Press- 8 HOT/ 10 COLD | eBay 1 Link to comment Share on other sites More sharing options...
anand.s Posted May 24, 2022 Share Posted May 24, 2022 1 hour ago, Dr4Film said: The 14 port Manobloc Model MXBD1B-14C2 is no longer in production. Your best plan would be to purchase the next size larger, an 18 port, then use the 14 and leave the others turned off. Viega 49183 ManaBloc 18-Port 1/2" Poly Press- 8 HOT/ 10 COLD | eBay They are also reversed! Hot is on the opposite side of the 14 port 🤔 Link to comment Share on other sites More sharing options...
Dr4Film Posted May 24, 2022 Share Posted May 24, 2022 (edited) There is nothing magic about hot & cold other than the color. They both turn on and off the flow. You just have to label what each one supplies and remember that Red is Cold and Blue is Hot. Or turn it upside down. Edited May 24, 2022 by Dr4Film Link to comment Share on other sites More sharing options...
Scotty C Posted May 25, 2022 Share Posted May 25, 2022 Just replaced mine on a 2000 Monaco. Mine was out of production but Viega built a new one ($185) in two weeks Link to comment Share on other sites More sharing options...
anand.s Posted May 25, 2022 Share Posted May 25, 2022 Good to know about low cost custom options. Will call them tomorrow. Link to comment Share on other sites More sharing options...
anand.s Posted May 27, 2022 Share Posted May 27, 2022 Thanks for the tips here - Viega is making one with the same mount points for $185 as Scott C noted. Solves my problem hopefully. Link to comment Share on other sites More sharing options...
Land Lubber Posted October 26, 2022 Share Posted October 26, 2022 Where is the Manobloc system located in my '09 Camelot? Is it behind the panel in the wet bay? Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted October 26, 2022 Share Posted October 26, 2022 On 5/22/2022 at 8:08 PM, Frank Bergamo said: I would also be concerned about the Aqua Hot internal loop. Air alone will not winterize your coach. You must pump RV antifreeze through system to insure no freeze damage. Could be an expensive lesson, good luck. I used air to blow all the water out of my water lines. I then left all the faucets open incase any water was in the lines. The temps where I was went down to zero several times. Never had and frozen pipe issues. Link to comment Share on other sites More sharing options...
Dr4Film Posted October 26, 2022 Share Posted October 26, 2022 4 minutes ago, Chuck B 2004 Windsor said: I used air to blow all the water out of my water lines. I then left all the faucets open incase any water was in the lines. The temps where I was went down to zero several times. Never had and frozen pipe issues. Chuck, big differencs between winterizing a standard RV hot water system and an Aqua-Hot system. The Aqua-Hot has multiple loops of a copper coil either on the outside or the inside of the boiler tank. Using just air for winterizing an Aqua-Hot is not recommended by the company in Colorado. It would be very difficult to remove all of the water from all of those loops with just air. Very expensive to replace a leaking Aqua-Hot system that ruptured because of water remaining in the loops during the winter. If you don't want to winterize an Aqua-Hot properly then your next best bet is to head south for the winter where the temperature seldom gets to the freezing level. Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted October 26, 2022 Share Posted October 26, 2022 True. I did not have aquahot so I did not have to deal with it. A $10,000 plus option with a costly yearly maintenance added on. My cheap water heater provided all the hot water I needed. Link to comment Share on other sites More sharing options...
