Wrayj1 Posted June 17, 2022 Share Posted June 17, 2022 Brought my 2007 Holiday Rambler Endeavor 40SKQ up from store, plugged in to 15 amp at home as usual to prepare for a trip. The fridge keeps diverting to has. Other 110 working, lamps, outlets etc. Any help appreciated. Link to comment Share on other sites More sharing options...
Dr4Film Posted June 17, 2022 Share Posted June 17, 2022 Check to make sure you have both 12 VDC and 120 VAC going to the control board and that the fuses are all good and functional. Link to comment Share on other sites More sharing options...
Ivan K Posted June 17, 2022 Share Posted June 17, 2022 If it works on gas, it got 12v power. If you force it to 110V AC and something isn't right, it should display a message. Link to comment Share on other sites More sharing options...
Wrayj1 Posted June 17, 2022 Author Share Posted June 17, 2022 Not sure how to force it to 110? Control board shows batteries fully charged, no other issues apparent with 110. Link to comment Share on other sites More sharing options...
96 EVO Posted June 17, 2022 Share Posted June 17, 2022 Unplug the fridge, and try another appliance / light, in that outlet. Link to comment Share on other sites More sharing options...
Ivan K Posted June 17, 2022 Share Posted June 17, 2022 Assuming it is a Norcold, where it shows a dot when running, make it to show AC by pressing Mode button until it does. 1 Link to comment Share on other sites More sharing options...
ok-rver Posted June 17, 2022 Share Posted June 17, 2022 I carry a 120 plug in voltage checker but a voltmeter or 120 lamp will work. Remove outside cover and check the outlet that the frig is plugged into. Just looked back and saw that 96 EVO stated the same thing but adding that the plug in is in the outside compartment. Ice maker was usually plugged into an inverter outlet. Refrigerator to shore power or generator supplied. I don't believe that this would be on a GFCI circuit but worth checking other outlets to confirm. Link to comment Share on other sites More sharing options...
Wrayj1 Posted June 17, 2022 Author Share Posted June 17, 2022 Thanks to everyone who posted suggestions. You know the old adage "who needs the instructions?". Pulled out the owners manual and it said, for my domestic 1452 model, to keep pushing auto/store button until auto stayed on, I pushed it a few times and once auto engaged it switched to ac for the fridge. 1 Link to comment Share on other sites More sharing options...
96 EVO Posted June 17, 2022 Share Posted June 17, 2022 Yeah, that was gona be my next suggestion ! Link to comment Share on other sites More sharing options...
CorinthWest Posted June 20, 2022 Share Posted June 20, 2022 Last weekend, spent an HOUR trying to figure out why there was no power coming from my EMS to the A/C's. Everything looked good, voltage to both legs of the 50 Amp service were good, all breakers looked good, but EMS was dead. Tried to start the generator, no crank. Started coach engine, then started generator, no EMS, no A/C's. Took cover off transfer switch, power in, power out, all good. Took cover off EMS breaker panel, checked 12 Volt fuse - dead, nada, zip, zilch, dead as roadkill. Thinking, thinking, thinking.......and then it came to me......I had shut off the Salesman's switch when I parked the coach at the storage facility. Turned the switch on, EMS powered up, A/C's came on, and everything was fine. As my mother used to tell me....."For a smart man, you can sure do some dumb s**t.". Lesson learned. Link to comment Share on other sites More sharing options...
96 EVO Posted June 20, 2022 Share Posted June 20, 2022 Ha, yeah that switch bite's a lot of people! Especially those who have hit it accidentally! Link to comment Share on other sites More sharing options...
Dr4Film Posted June 20, 2022 Share Posted June 20, 2022 Got rid of that nuisance POJ years ago on the Windsor. Our Dynasty doesn't have one so I no longer have to think about it ever again. Link to comment Share on other sites More sharing options...
CorinthWest Posted June 20, 2022 Share Posted June 20, 2022 I can certainly understand why (now). LOL God, did I feel stupid. Link to comment Share on other sites More sharing options...
