David M Posted September 9, 2022 Share Posted September 9, 2022 Good morning folks, I have a 2002 Monaco Dynasty. I am stuck in Provo, Utah. The reason I'm stuck is because I am in need of brake rotors, brake pads, and bearing seals for the front and one seal for the rear. I have folks from Rush Truck Center trying to locate parts and they are not having much success. If anyone has a suggestion where to look or the name of an after market company that might have these parts would be very helpful. I contacted Dana Corp. and was emailed some part numbers, they were not for the parts I need to replace. It seems that motorhomes and especially ones that are no longer manufactured are not at the top of the list of what people want to service. Ant help would be greatly appreciated. Thanks, David Link to comment Share on other sites More sharing options...
Ray Davis Posted September 9, 2022 Share Posted September 9, 2022 Check out this post. Link to comment Share on other sites More sharing options...
David M Posted September 9, 2022 Author Share Posted September 9, 2022 Thanks for the suggestion. My front brake problem is a more serious issue and the area where I am having the least amount success. Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted September 9, 2022 Share Posted September 9, 2022 In the early 2000's I toured both Roadmaster plants located in Oregon and Indiana. Roadmaster used complete front axle assemblies manufactured in Dana axle plants. Your 2002 coach is two decades old. I would say that there are not many 2002 Monaco Dynasty's left today especially one's in need of front axle parts. Inventory is a huge expense for any business. Therefore finding replacement parts is a challenge. I would give Scott Zimmer of Source Manufacturing a call. 541-935-0308 If anyone can point you in a direction, he can. Good luck, Link to comment Share on other sites More sharing options...
vito.a Posted September 9, 2022 Share Posted September 9, 2022 (edited) Our front brakes are Bendix ABD22X Air Disc brakes. You can't just call Freightliner (or whoever) for part numbers. But they will have part numbers on them. They may also be listed on your original build sheet. Manual attached. Good luck! Bendix ADB22X Disc Brakes (Front).pdf Edited September 9, 2022 by vito.a Link to comment Share on other sites More sharing options...
WayneC Posted September 9, 2022 Share Posted September 9, 2022 Alberta Coach and Chassis in Alberta Canada 🇨🇦 has access to brake parts for Monaco coaches Ask for Steve Wayne 1999 Signature ceaser Link to comment Share on other sites More sharing options...
planodp Posted September 9, 2022 Share Posted September 9, 2022 Here is what I got and it's from this forums. Bill D's Monacoers.org Page 16 2/3/2020 air disk - Dana Axle 04 Windsor Caliber, Haldex PN is K022919 05 Exec cross this number to a Bendix ADB22X Rotor Disk, Bendix PN is 977699 may also apply to other years Disk Pads, Bendix PN is 328863 Two per kit( 1 wheel only) and models. Seal, Chicago Rawhide PN CR35058 For use with Dana Axle E-1462W1462BN202-1 Axle SN HU00340643 Link to comment Share on other sites More sharing options...
MHRookie Posted September 10, 2022 Share Posted September 10, 2022 (edited) Start researching parts for the ADB1560 brake system. This is what my 2003 took. The rotors are the difficult piece to this puzzle. The shop is going to have to take one off to get the part numbers off to cross reference. I hope this helps. Book will show a left & right caliper. Monaco used same part & just flipped it on mine. Pads were easiest to find Good luck. Here is my info I used to search from numbers on my coach parts obsolete Meritor but have narrowed it down to: A1 or A2 - 3263M1157’s - it depends on the number stamped on the end of the shaft on the slack adjuster. To note (it could be L or R BUT one can be used for both. I doubt I’ll need calipers and since pads are common I’ve stopped looking). brake pads are: KIT15616(single) / 15626PM (set) Edited September 10, 2022 by MHRookie Link to comment Share on other sites More sharing options...
Corgidad Posted September 10, 2022 Share Posted September 10, 2022 When I replaced the brake pads and seals in the rear earlier this year I removed them and took them to NAPA where they cross referenced the part numbers that were on the parts and I had them the next day. Hope this helps and good luck with your repairs. Link to comment Share on other sites More sharing options...
