TDaleABQ Posted March 5, 2023 Share Posted March 5, 2023 Hello, I have a 2007 Monaco Knight with a co-pilot issue. All functions work correctly except for forward and backward movement. It is only working on one track. The I do have the chair out and can see that the worm screw on one side is moving but not the other when pushing the button. Thank you for taking time to look at this issue. Tim IMG_4787.mov Link to comment Share on other sites More sharing options...
Dr4Film Posted March 5, 2023 Share Posted March 5, 2023 I don't know exactly how these seats work. Possibly one motor is working and one is not? Does one motor run one side rail and the other motor works the other? Only throwing out some guesses. Link to comment Share on other sites More sharing options...
MyronTruex Posted March 5, 2023 Share Posted March 5, 2023 It looks like the bottom motor is being used??? It also looks like it has a shaft out of each end ???? Could have counter rotating screws so it could use the same direction on the motor. Link to comment Share on other sites More sharing options...
TDaleABQ Posted March 5, 2023 Author Share Posted March 5, 2023 1 hour ago, Dr4Film said: I don't know exactly how these seats work. Possibly one motor is working and one is not? Does one motor run one side rail and the other motor works the other? Only throwing out some guesses. No there is only motor for that function. Thanks IMG_4787.mov 1 hour ago, myrontruex said: It looks like the bottom motor is being used??? It also looks like it has a shaft out of each end ???? Could have counter rotating screws so it could use the same direction on the motor. There is only one motor for this. Please see video. Thanks for the help. IMG_4787.mov Link to comment Share on other sites More sharing options...
Dr4Film Posted March 5, 2023 Share Posted March 5, 2023 I would look at why the one motor at the bottom of the video is not turning the other shaft on the left. Is something loose or broken? Link to comment Share on other sites More sharing options...
MyronTruex Posted March 5, 2023 Share Posted March 5, 2023 Sure looks like a broken shaft on the motor, or connection. A longer and more close up of the left side of the motor would help. Link to comment Share on other sites More sharing options...
Bandit411 Posted March 5, 2023 Share Posted March 5, 2023 Did you try to assist the shaft turning while moving the button. It could be stuck or have something binding it. Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted March 6, 2023 Share Posted March 6, 2023 Does the other motor change the slope of the seat? Gary 05 AMB DST Link to comment Share on other sites More sharing options...
TDaleABQ Posted March 6, 2023 Author Share Posted March 6, 2023 Yes. There are actually four motors doing different motions. The one causing the problem is the bottom one that moves the screws on each side to go forward and backward. Only one is working. Thanks IMG_4787.mov Link to comment Share on other sites More sharing options...
Ivan K Posted March 6, 2023 Share Posted March 6, 2023 Looks like the shaft is inside a tube to each side? I would assume it to be a single shaft left to right and either broken (as mentioned earlier) on the left portion or the left gear box is out. Can't tell what is the piece on left of the motor looking like a spring or thread? Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted March 6, 2023 Share Posted March 6, 2023 (edited) Sorry, didn't know there was a video. Looks like the right side worm gear is working till it binds the left side seat slide. The left worm gear isn't transferring the rotation of the left side worm gear from the motor to the left longer shaft. A bad transfer gear box? Hope it makes sense. Gary 05 AMB DST Edited March 6, 2023 by Gary 05 AMB DST better explanation Link to comment Share on other sites More sharing options...
Tom McLoughlin Posted April 12, 2023 Share Posted April 12, 2023 I have a 2006 Monaco Knight with the opposite problem. All seat functions work but for the foot rest. Have confirmed the motor is huffed. Anyone know where to find a replacement motor? Thanks Tom McLoughlin 2006 Monaco Knight Dublin, OH Link to comment Share on other sites More sharing options...
TDaleABQ Posted April 15, 2023 Author Share Posted April 15, 2023 Hi Tom, Just to verify, when you push the foot rests button you do not hear the motor? It is located on the back portion of the seat. If you do hear the motor, I would say that is not your problem now that I have been through a rebuild on this seat. Link to comment Share on other sites More sharing options...
