Stephen Walsh Posted March 12 Share Posted March 12 Driver side shade motorized shade quit Anyone had this issue? Where can we we get a new one or fix this one? Link to comment Share on other sites More sharing options...
jacwjames Posted March 12 Share Posted March 12 Do you know the make/model of the shade?? I have a Carefree of Colorado, I had to replace the motor in the passenger side. Link to comment Share on other sites More sharing options...
Garry Donohue Posted March 12 Share Posted March 12 I have the exact same problem but mine will go up, but won’t go down. Would it be the Carling switch in the side panel? Link to comment Share on other sites More sharing options...
jacwjames Posted March 12 Share Posted March 12 On mine the wires were ran up into the ceiling above the dash, the connectors were accessible by pulling the wire out. If yours is the same way you can test the shade by pulling the wires out, taking loose and applying power. If good the shade would go up or down, the motor is reversible by swapping wires. I had to test mine before reinstalling so I got the direction right. Again, mine are Sun Visor by Colorado. Attached is the replacement motor I got, the new one is smaller then original but fit into the plastic case and had the same 50 RPM. Seems to work fine. I bought off of Amazon. Link to comment Share on other sites More sharing options...
Steve Hepfer Posted March 13 Share Posted March 13 Check your fuses. I had the same issue and it turned out to be a blown blade fuse Link to comment Share on other sites More sharing options...
Chargerman Posted March 13 Share Posted March 13 Be sure to check if you have voltage at the motor when the switch is activated. When mine died it ended up being the switch. Link to comment Share on other sites More sharing options...
Stephen Walsh Posted March 13 Author Share Posted March 13 Thank you Link to comment Share on other sites More sharing options...
throgmartin Posted March 14 Share Posted March 14 Whenever trouble shooting an electrical circuit always start at the power source. Is there power to the switch ? Yes. Is there power after the switch when depressed ? No. The switch is bad. If yes then go to the motor. Just last week I had a customer come in with two brand new motors for his front shades. He said " I need the motors replaced ". He got real testy when I said we would check the switch first before doing anything else. He swore up and down that the motors were bad. I refused to listen. Turned out it was the switch. Never assume the worst. Always start with the simple stupid stuff first. If I had listened to the customer I would have had the motors replaced by my techs and he would have had a hefty labor bill. If you have a pain in your kidney and go to the Doctor do you want him to test to see if it is a kidney infection or just cut you open and remove your kidney ? Same applies with many components on your coach. 🙂 2 Link to comment Share on other sites More sharing options...
beemerman Posted March 14 Share Posted March 14 On my 2003 Dynasty the shades switch directions when the switch is depressed. One time when the switch is pressed the shade will go up and the next time the switch is pressed the same direction the shade will go down. I can't quite get my head around how that happens. Link to comment Share on other sites More sharing options...
Bill R Posted March 14 Share Posted March 14 X2 @throgmartin my drivers side shade was erratic. Pulled the switch and the connector popped out. Reconnected, wrapped some electrical tape to secure better, and no problems since. Link to comment Share on other sites More sharing options...
jacwjames Posted March 14 Share Posted March 14 (edited) X2 on checking the simple stuff first. A mulitmeter is your friend. When I had trouble with my shade I tested and had power but the thing wouldn't move. When I took it down it was clear what was wrong, the motor got so hot it melted the plastic mount that it was attached to. Luckily I was able to pry it off/out of the mount and somewhere found a lead for a source of a new motor. Carefree doesn't support that model of sun visor so the one I posted is aftermarket. My guess is that my wife stacked something on her passenger side console and the button was pressed causing the motor to overheat but the fuse didn't blow. We did have the fuse blow once when both of us were trying to move the passenger side shade, so not sure why it didn't blow this time. FWIW she started to get in the habit of staking things on drivers side console and steering wheel. Had a problem with something and told her no more stacking stuff on any of the consoles. Edited March 14 by jacwjames Link to comment Share on other sites More sharing options...
Gweedo Posted March 14 Share Posted March 14 Check the switch, if you need a motor you will pay a lot more for the original replacement. you can pick up a universal on Amazon for a 3rd of the cost and retrofit it. just a thought. Link to comment Share on other sites More sharing options...
