Kjungles Posted June 17, 2023 Share Posted June 17, 2023 Inverter keeps going to an error solid red light. Battery state of charge is consistently around 70%. Says it’s bulk charging but not going any higher than 71% Link to comment Share on other sites More sharing options...
MyronTruex Posted June 17, 2023 Share Posted June 17, 2023 I would suggest getting a voltmeter across the batteries first. Could be some cratered cells dragging things down. Link to comment Share on other sites More sharing options...
Tom Cherry Posted June 17, 2023 Share Posted June 17, 2023 35 minutes ago, myrontruex said: I would suggest getting a voltmeter across the batteries first. Could be some cratered cells dragging things down. kill the house battery switch. Remove the jumpers from each set of batteries. Measure the voltage of each battery. At 70% charged, each battery should read 6.15/.25. They all should be within maybe 10% (not ten volts) of each other. If you have one or maybe 2 that are way lower…like in the mid 5’s…..rearrange your batteries and put in one set….the good ones……jumper them. Do NOT put the jumpers on the bad ones…. THEN turn on the house switch. I IF you have a Magnum inverter, google SOFT RESET or START. Hold in the Power button for 20 seconds…..wait 5 minutes of so. Push the power button once to start or power on the inverter. Monitor what happens and report back. Link to comment Share on other sites More sharing options...
vito.a Posted June 17, 2023 Share Posted June 17, 2023 I recommend removing the loads and the supply current and restart it. 2005 and earlier coaches came with the Trace Freedom inverters. They were purchased by Xantrex and production moved offshore. Xantrex customer support at 1- 800-670- 0707 Link to comment Share on other sites More sharing options...
