Robert92867 Posted August 26, 2023 Share Posted August 26, 2023 My rear brake rotors have become critical. What I have found so far is possible match to Centric 120.83015 (a Workhorse W22 video) and another forum listing 54770P-65 ABS rotor that matches to a '03 34pdd Cayman that likely has a higher GVW rating, less likely to match. Ultimately, I will have to pull the parts and match them but there is always hope someone has done this before. Link to comment Share on other sites More sharing options...
allphase8 Posted August 26, 2023 Share Posted August 26, 2023 Not a break expert by any stretch. But have had to replace rotors on my Camelot a couple of times. I do not think those surface cravings are a killer. You need to be concerned if the crack goes through the rotor. JMO. Link to comment Share on other sites More sharing options...
Solution Ivan K Posted August 26, 2023 Solution Share Posted August 26, 2023 I also would not call it 'critical' just yet but you are right looking for replacent parts. My Meritor manual calls for replacing them but I wouldn't panic yet. Sorry, can't help with your part numbers. Link to comment Share on other sites More sharing options...
Paul J A Posted August 27, 2023 Share Posted August 27, 2023 Clean up the TAG on your axle and it will provide all the information you need to give to a truck shop that does that work. Link to comment Share on other sites More sharing options...
Robert92867 Posted August 27, 2023 Author Share Posted August 27, 2023 Thanks Ivan. Take a look at the attached video. It's close to being like figure 8.2, but not quite there... cropped rotor video.mp4 Link to comment Share on other sites More sharing options...
lake49068 Posted August 27, 2023 Share Posted August 27, 2023 Should be a manufacturer's tag with serial number on the axle (most likely Dana but could be Eaton or Meritor). Pretty sure Monaco/HR received the axles "dressed", ie, complete with brakes. Contact axle supplier's tech service and they should have the parts breakdown for that assembly. "Back in the day" when employed by Eaton/Dana Axle, their files and tech service were excellent in providing this type of info. Link to comment Share on other sites More sharing options...
Ivan K Posted August 27, 2023 Share Posted August 27, 2023 11 hours ago, Robert92867 said: Thanks Ivan. Take a look at the attached video. It's close to being like figure 8.2, but not quite there... cropped rotor video.mp4 29.08 MB · 0 downloads Bob, personally, it would not stop me from driving it while collecting replacements. Just don't want the cracks get to the edge or start eating up the pads. Up to your level of comfort. As others said, data plate on axle will help the manufacturer identify all the parts you need. I have Rockwell axles and it took them all of two minutes to get me the part numbers. Heavy but otherwise not hard to replace. Link to comment Share on other sites More sharing options...
