96 EVO Posted October 16, 2023 Share Posted October 16, 2023 Yeah, mine takes up about 2/3 of the valve cover. Link to comment Share on other sites More sharing options...
Steven P Posted October 16, 2023 Share Posted October 16, 2023 11 hours ago, Bill R said: @Steven P You should have a crankcase breather with a drain tube back to the crankcase and blowby tube that runs down and exits by the starter. @96 EVO is correct that our year 400ISL engines do not have the filters though. See image below. Number 6 points to the crankcase breather on top of the engine. Thanks Bill! So, to confirm, there's no filter so no preventative maintenance for the breather? May I ask the source for the diagram you shared? Thanks! Steven Link to comment Share on other sites More sharing options...
Bill R Posted October 16, 2023 Share Posted October 16, 2023 Yes no filter, but you can easily pop the lid to confirm. The source was from Cummins Quickserve. 1 Link to comment Share on other sites More sharing options...
Happycarz Posted October 16, 2023 Share Posted October 16, 2023 Steven, There is not much to this filter, as you can see once it is cut open. It rests on top of valve cover toward the center. My engine is a 2006 and should look very much like yours. 2 Link to comment Share on other sites More sharing options...
Gary Cole Posted October 16, 2023 Share Posted October 16, 2023 Harry you have a very nice looking engine. 1 Link to comment Share on other sites More sharing options...
Happycarz Posted October 16, 2023 Share Posted October 16, 2023 Gary, thank you very much. 1 Link to comment Share on other sites More sharing options...
b_faster Posted October 17, 2023 Share Posted October 17, 2023 18 hours ago, Happycarz said: Steven, There is not much to this filter, as you can see once it is cut open. It rests on top of valve cover toward the center. My engine is a 2006 and should look very much like yours. Nice engine bay. I dont often see a turbo blanket on RV engines. 1 Link to comment Share on other sites More sharing options...
Happycarz Posted October 17, 2023 Share Posted October 17, 2023 With the exhaust and turbo wrapped I no longer have the bedroom heat issue. 4 Link to comment Share on other sites More sharing options...
Steven Schoepke Posted October 18, 2023 Share Posted October 18, 2023 On 10/10/2023 at 11:40 AM, Astro Imager said: Greetings to everyone! Starting the 1300 mile journey south for the winter season from Washington. We have some fairly steep climbs that I want to understand better about how to climb with the Alison in our 2009 Camelot 42’. Coming home this last June, we encountered a couple ‘Stop Engine’ lights and lost power at uncomfortable spots on the road. This summer I drained the coolant and flushed the system after degreasing and cleaning both sides of the CAC & the radiator. Re-Filled the coolant system with Final Charge (Red) and topped it off after a couple short runs as needed. I also replaced the recovery tank pressure cap. All this in hopes of not repeating the Stop Engine issues. My question is this; I’ve been told by several people I trust with years of diesel driving experience that I’m not driving the transmission aggressively enough if I’m just leaving it in D. Yet I have a very experienced friend on this forum who I’ll call my “Sensei”, tell me that it’s not necessary with the excellent Alison Transmissions we have. Can I help myself avoid these hot engine issues by keeping the RPM’s higher and the torque in a better range when starting up grades? Thank you for your consideration, Dale When climbing a grade I watch the Tach not the speed. I have a 2004 ISM 500 hp Cummins 4000 Allison, I keep the rpm between 1500 - 2100 rpms. Safe Travels! 1 Link to comment Share on other sites More sharing options...
