ktloah Posted March 4 Share Posted March 4 Looking for information on just where I can purchase these solenoids. I believe they have something to do with the cruise control. They are mounted on the firewall on the drivers side in the generator compartment. Thanks... Link to comment Share on other sites More sharing options...
Ivan K Posted March 4 Share Posted March 4 Pressure switches. One pair for brakes, the other to disable cruise. If you are certain they are bad, they typically have a visible part number on them to Google. Since they are simple 2 wire switches, there should be plenty of hits for them on the net. Link to comment Share on other sites More sharing options...
ktloah Posted March 5 Author Share Posted March 5 (edited) Ok, I will check for the #'s. Any idea what the bottom part of this is? Thank you Edited March 5 by ktloah Link to comment Share on other sites More sharing options...
Robert92867 Posted March 5 Share Posted March 5 Excuse my ignorance... those are in an '04 Dynasty? Link to comment Share on other sites More sharing options...
Chargerman Posted March 5 Share Posted March 5 What have you done to determine that they are bad? It would be highly unlikely that both are bad Link to comment Share on other sites More sharing options...
Ivan K Posted March 5 Share Posted March 5 1 hour ago, ktloah said: Ok, I will check for the #'s. Any idea what the bottom part of this is? Thank you Do you mean the parts circled in red? These should be your cruise cancel pressure switches, normally closed. The two large round ones above would then be low pressure brake switches, normally open. The part numbers would give it away. Link to comment Share on other sites More sharing options...
ktloah Posted March 5 Author Share Posted March 5 Ok thanks...my Cruise works intermittently...hoping replacing these will solve my problem....thanks again Hey Steve, not sure they are bad, but the cruise cancel solenoid is suspect Yup, 04 Dynasty Robert... Link to comment Share on other sites More sharing options...
Ivan K Posted March 5 Share Posted March 5 They are easy to test before throwing parts at it and to confirm which is which. As Chargerman said, the likelihood that both in the pair are bad is not great, possible but worth testing first with a simple ohm meter or whatever circuit tester. Open vs closed with brakes applied and released, with air in tanks of course. Link to comment Share on other sites More sharing options...
cbr046 Posted March 5 Share Posted March 5 50 minutes ago, ktloah said: Ok thanks...my Cruise works intermittently...hoping replacing these will solve my problem....thanks again When my cruise control was acting up it turned out to be the primary fuel filter clogging. Strange but true. Is it time? - bob 1 Link to comment Share on other sites More sharing options...
ktloah Posted March 5 Author Share Posted March 5 Yup, 04 Dynasty Robert... Link to comment Share on other sites More sharing options...
