Popular Post Ivan K Posted March 9 Popular Post Share Posted March 9 I have spent a lot of time under the coach last fall eliminating air leaks, replaced all PPVs, bunch of fittings, replaced orings in sixpacks, hydraulics etc. All seemed good after that. Couple of days ago I pulled the coach out of the shop, shut it at ride hight and half an hour later noticed a significant leaning. Driver side bags dropped 2 inches. Here we go again. Raised the low driver side manually to level and it stayed that way. Weird. Drove it back into the shop yesterday and it leaned again after shutting down. Initially thinking I have to work on the low driver side, I investigated closer and found that while driver side goes down 2", passenger side goes up the same but only if there is plenty pressure in the tanks. Ok, that makes sense now and explains why it was so seemingly random. Solved by replacing the plunger in passenger side sixpack raise valve. Five minute job without even removing the valve body. All good now. I just thought to mention it, it's not always a leak that can be detected with bubbly water and sometimes counterintuitive, just if someone runs into similar situation. 10 3 Link to comment Share on other sites More sharing options...
Jim Pratten Posted March 9 Share Posted March 9 Interesting and good job troubleshooting. I’m almost dangerously smart on how HWH works and appreciate insight like this. Am I correct in guessing it was the rear six pack? Link to comment Share on other sites More sharing options...
Solution Ivan K Posted March 9 Author Solution Share Posted March 9 5 minutes ago, Jim Pratten said: Interesting and good job troubleshooting. I’m almost dangerously smart on how HWH works and appreciate insight like this. Am I correct in guessing it was the rear six pack? Yes, correct, it was drive axle sixpack valve letting air into the bags in my case. Link to comment Share on other sites More sharing options...
Jdw12345 Posted March 10 Share Posted March 10 So you must carry a generous supply of spare parts to cover the air leveling system also then? Link to comment Share on other sites More sharing options...
Ivan K Posted March 10 Author Share Posted March 10 6 minutes ago, Jdw12345 said: So you must carry a generous supply of spare parts to cover the air leveling system also then? Haha, yeah but mostly parts to repair the large parts, not necessarily to replace them. Link to comment Share on other sites More sharing options...
96 EVO Posted March 10 Share Posted March 10 Glad you posted your finding 👍! Seems to be a rash of 'coach leaning' threads recently. Link to comment Share on other sites More sharing options...
Trevor and Laura Posted March 10 Share Posted March 10 Hi Ivan, so far we have not had to deal with any air problems on our new to us Dynasty, but I have been reading and trying to prepare for the "when" it happens. You initially said that the drivers side dropped, but then the passenger side raised, and you fixed that, so did the DS not drop? We have gathered a few hydraulic bits but have no pneumatic spares yet and wondering if there are lists of suggested parts for the various models, hoping... thankyou so much for sharing. Trevor Link to comment Share on other sites More sharing options...
Ivan K Posted March 10 Author Share Posted March 10 Yes, both statement are true. The driver side dropped because of weight transfer when passenger side raised. Once the air leak inflating the passenger side was eliminated, it stays level at correct hight now. All this was happening with air leveling OFF. As far as spare parts, the easiest in this case would be to have a complete spare sixpack valve, depending on manufacturer of your system they are different. I carry one complete spare valve but also have several sets of orings, plungers and a coil to repair a malfunctioning valve if I wasn't in a hurry to just get on the way. The list could be never ending, I just get some extras when I have to fix something, for next time. 1 Link to comment Share on other sites More sharing options...
Lionel Posted March 11 Share Posted March 11 Ivan do you have a part number or source for the sixpack valve. Lionel Link to comment Share on other sites More sharing options...
rustykramermetalfab Posted March 11 Share Posted March 11 Ivan, is there an Oring kit available for the HWH system valves/solenoids? That is something I have not really been into yet. I am just thinking this is something good to have on the road while traveling if you have a leak severe enough to keep you from moving? I have a pretty good supply of lines and fittings. Thanks Link to comment Share on other sites More sharing options...
Ivan K Posted March 11 Author Share Posted March 11 2 hours ago, Lionel said: Ivan do you have a part number or source for the sixpack valve. Lionel Lionel, this is how I got my spare recently, for HWH. Coaches without tag, they all will have 3/32 orifice. Tag coaches will also have 2 valves with 5/32 orifice, not important enough to have a spare on hand, for me. Link to comment Share on other sites More sharing options...
Ivan K Posted March 11 Author Share Posted March 11 3 hours ago, rustykramermetalfab said: Ivan, is there an Oring kit available for the HWH system valves/solenoids? That is something I have not really been into yet. I am just thinking this is something good to have on the road while traveling if you have a leak severe enough to keep you from moving? I have a pretty good supply of lines and fittings. Thanks Rusty, I heard that HWH sells oring kits but they apparently don't include the third, internal ring. I ordered my spares from theoringstore.com with the following dimensions. Some prefer viton rings, nothing wrong with an overkill but I went with cheaper fluorocarbon (18 each for complete rebuild on a tag rig) since we are dealing with air, not diesel and such in the leveling system. 1 Link to comment Share on other sites More sharing options...
Lionel Posted March 11 Share Posted March 11 Thx Ivan very much appreciated.Take care. Lionel Link to comment Share on other sites More sharing options...
Trevor and Laura Posted March 11 Share Posted March 11 Thanks Ivan, will be working on my shopping list while in the US, read somewhere that a levelling valve would be good, are they a generic thing or Monaco specific? Not sure about your weight transfer theory, maybe you would expect a leak to cause a drop? (think weight transfer causing a lean would be a dynamic/cornering condition) Thanks again, Trevor Link to comment Share on other sites More sharing options...
Ivan K Posted March 11 Author Share Posted March 11 Depending on make of your leveling system, the valves could be different. I only know HWH type which was used by other MH manufactures as well. Don't know who made them, doubt they are made in house by HWH but simply don't know. I sourced some old stock Skinner plungers and they fit fine, all I can tell. Coincidence? Maybe. If you want to disprove the weight transfer theory, raise one side by 2" and see what happens to airbag hight on the other side. 3 Link to comment Share on other sites More sharing options...
planodp Posted March 12 Share Posted March 12 Thanks for sharing the information, Ivan! After talking to you, I did discover that I had 3 low pressures switch 20 PSI and other leaks. Waiting for it to come in from HWH. In the means time started replacing the front air bags. The last 4 bags. The front has a 3/4 “air line with a 1 1/8 compression nut on it. What make ready bad is there is hardly any room on the back 2 bag. Ivan is this the plunger you are talking about? The silver piece in the middle. Would you have the part #? Thanks Link to comment Share on other sites More sharing options...
Ivan K Posted March 12 Author Share Posted March 12 Duey, yes that is the plunger I had to replace, the plastic face insert was leaking. As far as I know, there is no known part number to obtain it individually but Harry has posted a link for possible alternative part not long ago. I have not used it but seems promising: https://www.kleen-ritecorp.com/p-1975-kip-valves-pa-2x1138-ac-plunger-assembly-for-2x1138-24-60-solenoid-valve.aspx Link to comment Share on other sites More sharing options...
planodp Posted March 12 Share Posted March 12 Thanks Ivan, just order2 I'll let you know if it fit or not. 1 Link to comment Share on other sites More sharing options...
Georgia Mike Posted March 12 Share Posted March 12 When I first bought my Dynasty the front driver side leaned after 15 min. I went to Josams and they replaced a hose and an air bag. Then the passenger side started leaking down slowly….probably was always leaking but slower so I never noticed it. A year later went back to Josams and had 3 air bags replaced and everything seemed ok for a short time. Passenger side started leaking slowly again so this year I went back and they found another problem up front and fixed it. We camped for a week and all was good then I came home two weeks ago and parked it at our lot. I went over yesterday and guess what passenger side was down again. I have been under there so many times spraying for leaks and have replaced many fittings myself as well as Josams fixing it and still this persistent leak. They have checked the 6 packs and not found a problem. The rear has all the original air bags and never leaks only the front passenger where all the bags have been changed as well as hoses and many fittings. I guess I’m just destined to put my blocks of wood between the frame as I have been doing since I have owned it. Link to comment Share on other sites More sharing options...
Ivan K Posted March 13 Author Share Posted March 13 Or just park it with empty bags? I would put a wet finger on the exhaust hole on the sixpack first and feel for a leak. Link to comment Share on other sites More sharing options...
