Kenster Posted March 17 Share Posted March 17 What are you doing for a USB hub to run Dash mounted accessories like phone chargers, navigation, Tire monitors and a potpourri of other accessories? Either behind the dish or mounted to the Dash. Link to comment Share on other sites More sharing options...
BradHend Posted March 17 Share Posted March 17 On my Cayman I found a spare 12v wire in the rats nest under the drivers left side control station (under transmission selection and all the rocker switches). I purchased a few extra rocker switches, an in-line fuse holder and a USB power supply from Amazon, controlled by the new rocker switches in place of the blank fillers. I then cut a notch for the wiring in the cover material of the control station and routed the cable to my tablet and chargers on the left side of the dash. Tablet is for Bluefire, and then a USB female end for whatever else I may need, like for a phone charger or GPS. I’ll be heading over to the Moho this aft and will grab a couple pics to post if you’d like. 1 Link to comment Share on other sites More sharing options...
Martinvz Posted March 17 Share Posted March 17 (edited) We use a cigarette adapter for 2 ports. I also installed a 2 port outlet with 2 usb ports as an extension of the cigarette ports as the usb current draw is very low. These are on the passenger side and the plan is to move the usb outlet on the passenger side to the driver side and install a different 2 port usb without a voltage display where the current usb port is. The usb with the voltage display will be hooked up tho the chassis side so that I can see the battery voltage. The cigarette outlets and existing usb outlets are on the house 12v system Edited March 17 by Martinvz Added picture Link to comment Share on other sites More sharing options...
Dr4Film Posted March 17 Share Posted March 17 I use this 12 VDC splitter for powering my devices. Purchased at Amazon. https://tinyurl.com/2wvkjvaf Link to comment Share on other sites More sharing options...
Jim Pratten Posted March 17 Share Posted March 17 (edited) We use ones similar to this one in three location secured using VHB tape: Cabinet above windshield for router, jet packs . . . Dash for iPad, Garmen, TPMS . . . Bedroom TV cabinet for rechargable flashlights, family radios . . . Another consideration is how to connect these and other 12vdc devices to coach power. I’m not a fan of cigarette lighter sockets used for 12vdc power. Wherever we need to make a portable 12vdc connection, we use Anderson Powerpole connectors. When we replace a cigarette lighter outlet, I’ve used these. Edited March 17 by Jim Pratten Added content. 1 1 Link to comment Share on other sites More sharing options...
TomV48 Posted March 17 Share Posted March 17 For the driver's area I ran a 10 gauge wire up from the electrical control box below the driver's window into the dash area. I then mounted a dual receptacle surface mounted on the lower edge of the dash. 1 Link to comment Share on other sites More sharing options...
Ivylog Posted March 17 Share Posted March 17 EBay Link to comment Share on other sites More sharing options...
TomV48 Posted March 18 Share Posted March 18 I looked at those and the wiring was way too light to suit me. I used little appliances that let me run my chosen gauge of wire up to a 1/4 inch female blade connector. Link to comment Share on other sites More sharing options...
DBRV.0 Posted March 19 Share Posted March 19 On 3/17/2024 at 3:45 PM, TomV48 said: For the driver's area I ran a 10 gauge wire up from the electrical control box below the driver's window into the dash area. I like that idea, more than tapping an existing wire. Link to comment Share on other sites More sharing options...
