Chuck H Posted April 6 Share Posted April 6 I recently changed out the air dryer and knew I had this leak prior but I wanted to change out the dryer first for obvious reasons. The big green tube is leaking air on top of the tank right where it goes into the push fitting because it's at an angle and not straight out for 6 plus inches first before routing. My question would be can I add some tube using an inline connector? Sorry for the duplicate pics Link to comment Share on other sites More sharing options...
Ivan K Posted April 6 Share Posted April 6 Yes, I had to do the same on a ~30' long connection between tanks. If it was just a short run, i would replace it. Don't understand why some of the lines were cut so short. I used DOT compression fitting so there would not be an other potential leak point. NAPA sells tubing per foot. 2 Link to comment Share on other sites More sharing options...
Chuck H Posted April 7 Author Share Posted April 7 I'm not exactly sure where it goes to. I think it heads to the front of the coach possibly to the brake system. Link to comment Share on other sites More sharing options...
Chuck H Posted April 7 Author Share Posted April 7 I did use compression fittings as well when I replaced the dryer. Link to comment Share on other sites More sharing options...
Solution jacwjames Posted April 7 Solution Share Posted April 7 You can download the air system schematic and might tell you where the line goes & purpose. When I worked on my air system I had one larger hose/tube that was coming in at an angle and had a small leak. I replaced the Push to Connect fitting with a Compression type and got it to seal right up. Link to comment Share on other sites More sharing options...
Chuck H Posted April 7 Author Share Posted April 7 Thanks Jim I'll look for that schematic. Link to comment Share on other sites More sharing options...
Chuck H Posted April 7 Author Share Posted April 7 Well I tried to find where to download the schematic and I couldn't find it. Can you tell me how to accomplish that? Link to comment Share on other sites More sharing options...
Idoc57 Posted April 7 Share Posted April 7 35 minutes ago, Chuck H said: Well I tried to find where to download the schematic and I couldn't find it. Can you tell me how to accomplish that? I would also know how find and download the air system schematic for my 2006 Cayman 37 PBD. My tanks were leaking down pretty fast. Three days ago we found two 90 degree push-in fittings on the bottom of the front air tank leaking. I replaced them with compression fittings. Also found that the air line going to the left rear air spring was pinched by the upper shock mount bolt and was leaking. Repaired that one with a compression coupling. Its definitely not leaking down as fast now, but it still empties the tanks in about 10 hours. Seems to me that it used to take almost a week to empty the air tanks when it was just sitting still. All air springs are a year old. The only thing that I can think of that I didn't check is the air line and valve to the air horns. Does anybody know where to look for that valve? Other than the front and rear air tanks, the air springs, the WABCO air pump/ filter and the air horn line, is there any thing else in the air system to check? I'm curious if any of y'alls air tanks stay above say, 60 PSI for anywhere near a week. Thanks, Carey Link to comment Share on other sites More sharing options...
jacwjames Posted April 7 Share Posted April 7 Here is a link to what is available in the Downloads section https://www.monacoers.org/files/category/1-air-systems-leveling-jacks/ I had the attached in my files which is dated 1999, I found it very close to mine. AIR SYSTEM Dynasty and Windsor.pdf 2 Link to comment Share on other sites More sharing options...
bmulvenna@hotmail.com Posted April 7 Share Posted April 7 Maybe this will help https://docs.google.com/document/d/1MavKhp56HkngQ6Vs3Qhsdhc6favVG0yr1qATnKXWN4c/edit?usp=drivesdk 1 Link to comment Share on other sites More sharing options...
eddie4ne Posted April 7 Share Posted April 7 3 hours ago, jacwjames said: Here is a link to what is available in the Downloads section https://www.monacoers.org/files/category/1-air-systems-leveling-jacks/ I had the attached in my files which is dated 1999, I found it very close to mine. AIR SYSTEM Dynasty and Windsor.pdf 1007.51 kB · 8 downloads Jim, Thank you for the resources. All of your help has been GREATLY appreciated! Sharon Link to comment Share on other sites More sharing options...
jacwjames Posted April 7 Share Posted April 7 FWIW, I've owned my 2002 Windsor since 2008, so over the last 15 years I've accumulated a lot of information. Holler if you need something. 1 Link to comment Share on other sites More sharing options...
Chuck H Posted April 7 Author Share Posted April 7 Thanks Jim for the links. My gut tells me to replace that section of tube because it is coming into the fitting at an angle and is pretty tight plus that green tube disappears into a loom of a bunch of other stuff so I can't really see where it is routed. Do you think by looking at the pics I could put a compression fitting in its place or could I put in a short extension of tube with a inline connector? Link to comment Share on other sites More sharing options...
jacwjames Posted April 7 Share Posted April 7 I think a compression fitting would solve your problem, Nothing really to lose but trying it. Link to comment Share on other sites More sharing options...
Chuck H Posted April 7 Author Share Posted April 7 Ok thank you again Jim! I'll give it a shot. Link to comment Share on other sites More sharing options...
Chuck H Posted April 8 Author Share Posted April 8 Thanks to all of you for your patience. You all are why this forum is so helpful and successful. Link to comment Share on other sites More sharing options...
