gjh2916 Posted May 5 Share Posted May 5 Does anyone have a electronic copy of a service manual for a Samsung RF18HFENBSR residential refrigerator. My freezer has stopped getting cold stays around 55 degrees, frig is working fine stays right at 36-38 degrees. Evap and Condenser fans both work, no ice buildup, defrost circuit is working. No error codes. Red light on circuit board in back of frig is on constant, that's suppose to be normal. I would be flashing a code if something was wrong. I'm puzzled Link to comment Share on other sites More sharing options...
Bill R Posted May 5 Share Posted May 5 (edited) Here is mine. Have you tried to shutdown the unit for 5 minutes and restart? Samsung RF18 Manual.pdf Edited May 5 by Bill R Link to comment Share on other sites More sharing options...
gjh2916 Posted May 5 Author Share Posted May 5 Bill R Thank you for response, yes I have tried to shut down and restart, done this several times. Also it says your manual is not available, maybe it takes awhile to upload. I will try again tomorrow. Is your manual a service manual or owners manual? I'm looking for a service manual. Link to comment Share on other sites More sharing options...
Diane M. Posted May 5 Share Posted May 5 I think this link may be what you are looking for. User manual Samsung RF18HFENBSR (English - 88 pages) Diane Link to comment Share on other sites More sharing options...
Bill R Posted May 5 Share Posted May 5 I had to reload it. Should work now. Link to comment Share on other sites More sharing options...
gjh2916 Posted May 5 Author Share Posted May 5 Diane M yours is users manual I’m looking for a service manual Bill R Your manual is a users/owners manual I am looking for a Service/Repair Manual Link to comment Share on other sites More sharing options...
Jim Byrd Posted May 5 Share Posted May 5 I had the same problem with my RF18 in my coach, it worked fine for over 5 years before the problem developed. I couldn't find any refrigeration repairman willing to service it in place even though the compressor was accessible from the outside of the coach. I removed the refrigerator and took it to the shop, and they found it low on Freon and they found a leak in the refrigerator evaporator, and it was replaced it. I reinstalled the refrigerator in the coach and within 6 months developed the same symptoms, freezer not freezing. I removed the refrigerator from the coach for the second time and returned it to the shop. They had it in the shop for several month and chased several leaks and made repairs but were never able to prevent the Freon from leaking out. Their concussion was that the leaks were caused by corrosion on the inside of the tubing in an area unaccusable to repair. All of this was happening during COVID and refrigerators were in short supply. It just so happened that the shop had a used RF 19 that was the same outside dimensions of my RF 18 and I purchased it and installed it in my coach. So far so good, just keeping my fingers crossed. Jim Link to comment Share on other sites More sharing options...
Duffer51 Posted May 5 Share Posted May 5 I also had this same issue with my Samsung Refrigerator. Turned out to be the evaporator fan in the freezer. Watched a video on You tube, order the part and took me about 20 minutes to replace it. I got my replacement from PartsSelect.com, their part number is PS4138377. Link to comment Share on other sites More sharing options...
Dr4Film Posted May 5 Share Posted May 5 @gjh2916 Gary, I have attached the service manual for the older versions which could very well help you find the failed component. The major differences between the RF18 and the older models was the compressor type. It has a DIC compressor aka Digital Inverter Compressor versus the older type of compressors. Most of the other stuff is the same. There are diagnostic tests which you can perform to possible find out what is not working. Let us know what you find out. Samsung - RF195 - RF217 Service Manual.pdf 2 Link to comment Share on other sites More sharing options...
Solution gjh2916 Posted May 6 Author Solution Share Posted May 6 Richard Thanks for the service manual it worked for my RF18 frig. I finally diagnosed my problem, I have a 134A freon leak, I added freon, frig went back to normal operation for a couple of hours, then it went back to no cool in freezer. checked freon level and it is low again. No visible signs of freon leak, frig 7 years old but only actually run for about a year total time. Guess it's time for a new frig. Link to comment Share on other sites More sharing options...
Dr4Film Posted May 6 Share Posted May 6 @gjh2916 Glad that it helped but sorry to hear about the bad news and outcome for your fairly new RF18 fridge. That's a real bummer! The Samsung RF-197 I had installed in the Windsor back in 2012 is still working to this day. The new owner had to put in a new sensor in the upper fridge cooling area that had failed this past year. Plus the RF-197 that came with the Dynasty we purchased two years ago is still working great. Link to comment Share on other sites More sharing options...
Jim Byrd Posted May 6 Share Posted May 6 4 hours ago, gjh2916 said: Richard Thanks for the service manual it worked for my RF18 frig. I finally diagnosed my problem, I have a 134A freon leak, I added freon, frig went back to normal operation for a couple of hours, then it went back to no cool in freezer. checked freon level and it is low again. No visible signs of freon leak, frig 7 years old but only actually run for about a year total time. Guess it's time for a new frig. Unfortunately, you are experiencing the same problem that I experienced. The shop replaced the evaporator in the refrigerator, and it run fine for about 6 months and freon was low again. The shop had the refrigerator for several weeks and never was able to locate the leak. All my problems developed just a few months after the warranty expired. Link to comment Share on other sites More sharing options...
