dougknight86 Posted August 25, 2020 Share Posted August 25, 2020 As is well known, the headlights on our coaches leave a lot to be desired. I am planning a long trip in late October and am looking for some ideas of what can be done to improve visibility, should it become necessary to drive after dark. Doug Knight ’05 Dynasty w/ ‘14 CR-V Link to comment Share on other sites More sharing options...
Chargerman Posted August 25, 2020 Share Posted August 25, 2020 It is common that the headlights end up seeing lower than needed voltage and therefore dimmer lights than what they were designed for. I chose to swap out my bulbs for high quality fan cooled LEDs. Much much better visibility but I still choose not to drive at night unless absolutely necessary Link to comment Share on other sites More sharing options...
Ivan K Posted August 25, 2020 Share Posted August 25, 2020 X2 for the LED conversion. Replaced ours with 12000 lumen bulbs and no longer have to hang on someone's tail just to see where the road goes ahead of us. Hopefully you have your lights fed directly through relays and not through the light switch, even if LEDs were not in your future. I don't plan to drive through the night, it happens here and there for whatever reason and isn't so much of a problem anymore. 1 Link to comment Share on other sites More sharing options...
dougknight86 Posted August 25, 2020 Author Share Posted August 25, 2020 The headlights on my coach are “projector type”. I understand tha the LED’s don’t work well with this type of light. Am I misinformed. Do LED’s irk OK? Doug Knight ’05 Dynasty w/ ‘14 CR-V Link to comment Share on other sites More sharing options...
daveyjo Posted August 25, 2020 Share Posted August 25, 2020 I installed relays and powered the actual bulbs from a +12 volt feeder terminal if the front electrical bay of my former 2001 Diplomat. So the headlight switch turned on the relays which then supplied power to the lamps without going through the headlight switch. I found the relays as a set along with a wiring harness somewhere on-line. Try Googling headlight relays. Also, here is a 5 year old note I had saved about using relays. I just mounted the relays next to the headlights somewhere. Maybe even use the "professional" method Monaco used to use, i.e., just dangle the relays from the wires. Adding Headlight Relays Many Monaco coaches were originally wired with the headlight and dimmer switches directly controlling the headlights. That is, there was no interposed relay, so all the headlight current passed through both switches. Due to the voltage drop across the switches, and the length of wiring, the voltage at the headlight bulbs was far below 12 volts, and thus the headlights were quite dim. Attempting to use higher wattage bulbs only makes the problem worse, as the higher current causes even lower voltage. The most successful way of correcting this is to put two relays in the circuit (one for high beam and one for low beam), so that the high current path for the headlights is “battery to relay to headlights to ground”. The lower current "headlight control" path becomes “battery to headlight switch to dimmer switch to relay coil to ground”. You can use the same type relays that are commonly found in the electrical bay (the bay with several cube-shaped relays, fuses, and connections). In most cases, the circuit from the headlight switch to the headlights passes through this bay anyway. Specifically, the relay type you need is 30 Amp, 12 V, SPST (single pole, single throw, although double throw will work as well), available at Radio Shack or auto parts stores. You can use a Radio Shack part number 275-226 or a Tyco (formerly Bosch) relay with specs of 12V 30A. There will typically be 4 or 5 blade-type connections on the bottom of the relay, labeled as 30, 85, 86, 87, and (optionally) 87a. You can use corresponding female compression connectors on the wires that you will connect to the relay. The most difficult part of the modification may be finding the two wires that come from the headlight hi/lo switch (the steering column mounted switch you use to set the headlights to high or low) and go to the high and low headlight filaments. With any luck, they will pass through the bay where you want to mount the relays. Cut these wires and connect them to the relay terminals as follows: High beam wire from switch - to terminal 86 of relay 1; Low beam wire from switch - to terminal 86 of relay 2. Wire going to headlight low beams - to terminal 87 of relay 1; wire going to headlight hi beams – to terminal 87 of relay 2. A new ground wire from terminal 85 of each relay to a good ground point. 12V power wires to terminal 30 of each relay. These last connections should include inline 20 Amp fuses. The power source should be one that is always hot (not switched on by the ignition switch). Usually you will find a copper “bus bar” or connection strip that feeds other relays and circuits and can easily supply the needed current. You will not use terminal 87a of the relays, if present 2 Link to comment Share on other sites More sharing options...
Moonwink Posted August 26, 2020 Share Posted August 26, 2020 (edited) https://www.lmctruck.com/ Try calling these people. You can't buy the components locally for twice this price. Another thing I did so I can see down the road at night was replace the fog lights with a "HELLA 008283811 FF50 Series 12V/55W Halogen Driving Lamp Kit" https://www.amazon.com/HELLA-008283811-FF50-Halogen-Driving/dp/B000KIH97E/ These really put light down the road and I finally feel like I'm no longer outdriving my headlights. Like others have said, avoiding driving at night is the best way to go but when you must drive at night, it's nice to be able to see where you're going. Edited August 26, 2020 by Moonwink 1 Link to comment Share on other sites More sharing options...
Melvin Posted September 22, 2022 Share Posted September 22, 2022 On 8/26/2020 at 2:52 PM, Moonwink said: https://www.lmctruck.com/ Try calling these people. You can't buy the components locally for twice this price. Another thing I did so I can see down the road at night was replace the fog lights with a "HELLA 008283811 FF50 Series 12V/55W Halogen Driving Lamp Kit" https://www.amazon.com/HELLA-008283811-FF50-Halogen-Driving/dp/B000KIH97E/ These really put light down the road and I finally feel like I'm no longer outdriving my headlights. Like others have said, avoiding driving at night is the best way to go but when you must drive at night, it's nice to be able to see where you're going. I just made an upgrade on my 2001 Monaco Sig to the new Holley retro fit LED headlights that are designed for classic cars and trucks that fit and worked perfect on my coach. check out the you tube videos on the before and after. Link to comment Share on other sites More sharing options...
Tom Cherry Posted September 22, 2022 Share Posted September 22, 2022 Anyone made the upgrade to LED for a Camelot or Scepter. SUPPOSEDLY, the 2005 - 2011 headlights were the same. These are the housings that have large dust covers on the back and you need a SAME size bulb. There wiring connector is INSIDE the housing. Not a good place to work. Here is a link to the Amazon replacement that gets less than good reviews....but you see the issues. https://www.amazon.com/Camelot-2005-2011-Motorhome-Replacement-Headlights/dp/B01IC5GVH0 I have upgraded many vehicles to LED, so I am not a novice, but these seem to be a real "Challenge" Supposedly they are 9005 & 9006 bulbs... Supposedly the same headlight from a Ford 2005-07 F250-550 truck. Thanks Link to comment Share on other sites More sharing options...
Martinvz Posted September 23, 2022 Share Posted September 23, 2022 I also upgraded the coach headlights to LED and it was a great improvement. Then, after dark drove to a suitable place, did the measurements, and then corrected the headlight alignment. Now I can drive at night, should it really be needed. Link to comment Share on other sites More sharing options...
rcl285 Posted September 23, 2022 Share Posted September 23, 2022 One further advantage of adding the relays is that it takes the high headlight current off the SmartWheel system which is known to fail from overheating the connections on the control box. Dick L. 04 Imperial Link to comment Share on other sites More sharing options...
