markcalgary Posted October 10, 2020 Share Posted October 10, 2020 Bought a used hot dog compressor 15 years ago for airing up tires and general garage use. It had the audacity to die just as I was getting set to air up the tires to spec before a test drive. Wondering what the current consensus is for a replacement powerful enough to use for the motorhome, and portable enough to keep in a bay. Thanks Mark 2002 Diplomat 38 Link to comment Share on other sites More sharing options...
Onthego Posted October 10, 2020 Share Posted October 10, 2020 I would shop for one that is rated to 150PSI. Looking on the internet they run from $130. And up. Now much room can you give up.? Size may play a part on which model will fit. Link to comment Share on other sites More sharing options...
lake49068 Posted October 10, 2020 Share Posted October 10, 2020 I purchased a pancake compressor rated at 150 psi from Harbor Freight. Depending on their sales cycle or coupon, about $100. Since usage is minimal, not concerned about longevity but 5+ years already. Seems like all the smaller compressors come from China so brand is not too important. Link to comment Share on other sites More sharing options...
Dr4Film Posted October 10, 2020 Share Posted October 10, 2020 I purchased a pancake Craftsman air compressor from Lowes rated at 150 psi when they had them on sale for under $100. Link to comment Share on other sites More sharing options...
bobdinsmore Posted October 10, 2020 Share Posted October 10, 2020 A few years ago, I raised the motorhome's governor cut-off pressure to 135 psi and use that to air up the tires. Works well and caused no problems to the rest of the air system. Bob Dinsmore 2000 Diplomat 2 Link to comment Share on other sites More sharing options...
wamcneil Posted October 10, 2020 Share Posted October 10, 2020 (edited) I keep this 150psi trim compressor on board: a Bostitch CAP1512-OF 1.2 Gallon Oil-Free High-Output Trim Compressor More expensive than the pancake compressors, but fairly quiet. It also runs fine on 2000w inverter. Cheers Walter Edited October 10, 2020 by wamcneil Link to comment Share on other sites More sharing options...
veraken Posted October 10, 2020 Share Posted October 10, 2020 This what I purchased from HD. They periodically have it on sale for $99.https://www.homedepot.com/p/RIDGID-6-Gal-Portable-Electric-Pancake-Air-Compressor-OF60150HB/303379052I then went to HF and purchased the following which I put on a slip mount near the compressor. Cost @$60 after 20% offhttps://www.harborfreight.com/38-in-x-50-ft-retractable-hose-reel-62344.htmlAfter adding the necessary fittings, it works great. Don't have to run the motorhome to air up the tanks and when not on shore power, I just run the generator. 1 Link to comment Share on other sites More sharing options...
Paul A. Posted October 10, 2020 Share Posted October 10, 2020 I meet a guy in Indio, Ca. in 11-2005 at a RV Park who was inflating his coach tires with a powertank.com . He was a distributor for the product. I purchased a 15# Tank and all the accessories for the use of it. I had the tank filled with Nitrogen, MY choice. It was amazing. Filled coach tires from 105# to 110# in less than -1- minute. I installed it in the coach basement, with quick disconnects, and used a 50' hose to air up the coach and toad from either side of the coach. The tank of nitrogen would last 1 to 1-1/2 years between refills, costing between 12-14$ at Gas Supply businesses around the country as we were Full Timers. I paid 495$ for it, and Sold it in Spring of 2014 for 350$. I would do it again . 1 Link to comment Share on other sites More sharing options...
