Steven P Posted October 13, 2020 Share Posted October 13, 2020 Hello all, I've been working on my to do list and since I've had the coach, the transmission temp gauge has not worked on the dash. It does work in the Aladdin but not in the scan gauge. I have removed the lead at the transmission, cleaned it and it didn't change. I think my next step would be to change the sensor out. I haven't found a replacement yet. Any suggestions on where to order one from? Tranny model#: E012544 Thank you. Link to comment Share on other sites More sharing options...
Scotty Hutto Posted October 13, 2020 Share Posted October 13, 2020 Ditto... I’ve never been able to get mine to work properly either. Hopefully someone can point us in the right direction I also added a new ground wire in my attempts to get it to work. 1 Link to comment Share on other sites More sharing options...
JDStew Posted October 13, 2020 Share Posted October 13, 2020 1 hour ago, Steven P said: Hello all, I've been working on my to do list and since I've had the coach, the transmission temp gauge has not worked on the dash. It does work in the Aladdin but not in the scan gauge. I have removed the lead at the transmission, cleaned it and it didn't change. I think my next step would be to change the sensor out. I haven't found a replacement yet. Any suggestions on where to order one from? Tranny model#: E012544 Thank you. Hi Steven - Interesting that the Aladdin is showing tranny temp. This would indicate that at least one tranny temp sensor is working and that the Aladdin can read it. This would make me wonder where the 2nd tranny temp sensor is, as that may be the issue. Or, if there is only one tranny temp sensor, I wonder why the dash temp gauge is not getting the signal that the Aladdin is. Are you able to read the resistance on the temp sensor at the tranny and compare that reading you get on the wire at the gauge? Keep us updated! Jeff Link to comment Share on other sites More sharing options...
Jon__C Posted October 13, 2020 Share Posted October 13, 2020 My MD3060 tranny temp doesn’t work on scangauge either, i think it requires manual setup on scangauge as an xgauge but I haven’t called them yet to verify, does anyone have one working? Thx Jon Link to comment Share on other sites More sharing options...
MBLSafariGazelle Posted October 13, 2020 Share Posted October 13, 2020 I thought the same thing in ‘05 Safari with C9. The mechanic at Sacramento Truck told me there are two sensors. He heated it up to verify dash gauge is working though far behind the Alladin reading. The reading temps eventually are the same. I’ve seen the dash gauge go up on long hill climbs since then, otherwise in normal driving it doesn’t move. I watch the Alladin screen in these hill climb situations because the dash engine temp gauge climbs into the high range and alarm starts to buzz while the Alladin will show temperature increase, though still ok. I was told the gauges used are not so accurate compared to the Alladin readings. I tow a F150 crew cab. Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted October 13, 2020 Share Posted October 13, 2020 WW Williams is the Allison transmission authorized distributor and repair/parts facility for Allison transmissions. Go to their web site to find the nearest dealer where you are located. Chuck B 1 Link to comment Share on other sites More sharing options...
Romeo84 Posted October 13, 2020 Share Posted October 13, 2020 Mine just started ticking... like it's going out. Im interested to see if there is a resolve to this. Btw what's an Aladdin? Link to comment Share on other sites More sharing options...
MBLSafariGazelle Posted October 13, 2020 Share Posted October 13, 2020 The Aladdin is a data system for engine, transmission and coach with display in the dash monitor. Link to comment Share on other sites More sharing options...
Steven P Posted October 14, 2020 Author Share Posted October 14, 2020 8 hours ago, Romeo84 said: Mine just started ticking... like it's going out. Im interested to see if there is a resolve to this. Btw what's an Aladdin? My Aladdin shows pretty much all engine and transmission info and the display doubles as the camera screen. There are 2 types of Aladdins to my knowledge. 1) Aladdin Jr-- what i have and 2) Aladdin-- this one adds in house monitoring info from what I've seen. 11 hours ago, JDStew said: Hi Steven - Interesting that the Aladdin is showing tranny temp. This would indicate that at least one tranny temp sensor is working and that the Aladdin can read it. This would make me wonder where the 2nd tranny temp sensor is, as that may be the issue. Or, if there is only one tranny temp sensor, I wonder why the dash temp gauge is not getting the signal that the Aladdin is. Are you able to read the resistance on the temp sensor at the tranny and compare that reading you get on the wire at the gauge? Keep us updated! Jeff Jeff, I have a VM w ohms, but am not too familiar w taking those readings. How do I do that? Thank you, Steven Link to comment Share on other sites More sharing options...
JDStew Posted October 14, 2020 Share Posted October 14, 2020 Hi Steven - just watched this video to make sure. When you have the sensor out, set your VM to ohms - about 2000ish range. Attach leads to each pin. Should read some value (1500 ohms or so?). When you hold the sensor, your body heat will change the resistance and should see it lower. Here’s the link: How to verify oil sensor works (that’s what I googled for sanity check) let’s us know what you find and post some pics please 🙂 Link to comment Share on other sites More sharing options...
pulsarjab Posted October 14, 2020 Share Posted October 14, 2020 The Allison manual list three different temperatures from three different senders located in different positions in trans and radiator. You have to know which sender your scan gauge, dash gauge, are wired to in order to set limits. I have just used the lowest temp in the manual to avoid the issue and no problems. Link to comment Share on other sites More sharing options...
Steven P Posted October 15, 2020 Author Share Posted October 15, 2020 @codelld interesting find! I cannot get that link to work, could you try again? Do you have a pic of the sender's location on the transmission? Thank you, Steven Link to comment Share on other sites More sharing options...
Gwarsh Posted October 15, 2020 Share Posted October 15, 2020 12 hours ago, codelld said: I found the VDO Part# 323-095 sender at the following URL.http://store.42draftdesigns.com/250F-Water-Temp-Sender-18-NPT_p_ 90.html. Steve, Try googling just "250F-Water-Temp-Sender-18-NPT_p_90.html", should see quite a few hits... Good luck! Link to comment Share on other sites More sharing options...
Steven P Posted October 15, 2020 Author Share Posted October 15, 2020 @JDStew thanks, I watched the video and that makes sense. @pulsarjab I'll download the manual and look this over. I did not know there are 3 sensors. Thank you. Link to comment Share on other sites More sharing options...
