Guest terry05dip Posted March 17, 2021 Share Posted March 17, 2021 Looking for information. This is on a 05 Dip. I recently got on the roof and notice some minor concave areas. Upon further inspection, the metal exterior roof and the under styrofoam seem to have a gap ( my limited opinion). Especially closer to the edge. I went ahead and pull the rear air conditioner to try to see between the two. Around that area the metal and styrofoam is glued tightly together. I have done maintenance as necessary. I have no known leaks. The coach has been garaged its entire life. Could this be because of the age of the coach and the styrofoam deteriorating? Any other ideas? Link to comment Share on other sites More sharing options...
PeterSchweizer Posted March 17, 2021 Share Posted March 17, 2021 Please Include some photos of issue Link to comment Share on other sites More sharing options...
Guest terry05dip Posted March 17, 2021 Share Posted March 17, 2021 Hard to see in photos. I can push down on the roof and get about 3/4 in off play. Link to comment Share on other sites More sharing options...
Bill Morgan Posted March 17, 2021 Share Posted March 17, 2021 (edited) According to a recent post, some 2003-2005 Exec and Signatures that were built in Coberg, WA had bad welds on crossbars supporting A/C units. Might want to check into this or do a search on here. Edited March 17, 2021 by Bill Morgan Link to comment Share on other sites More sharing options...
Guest terry05dip Posted March 17, 2021 Share Posted March 17, 2021 Coach was produced in Indiana. It just seems strange that it seem to happen all at once Link to comment Share on other sites More sharing options...
Guest sunriseranch2000 Posted March 18, 2021 Share Posted March 18, 2021 Fellow Campers, We had an '04Dynasty with no roof problems and bought a new '05Dynasty produced in Coberg. Drove it across country to SC and found all three roof ACs had sunk into the roof and water was pounding around them. Took it to Florida for warranty repair and was told by Monaco to bring it back to Coberg. The roof design had been changed for the '05 Monaco's. They added extra roof framing around the ACs to raise them back up. It was NOT an easy job. Good luck, Bob and Sunny Penland Link to comment Share on other sites More sharing options...
Bob Nodine Posted March 18, 2021 Share Posted March 18, 2021 17 hours ago, terry05dip said: Hard to see in photos. I can push down on the roof and get about 3/4 in off play. We have and 2006 Diplomat and ours is a lot worse than yours. The roof structure is an aluminum frame with crossmembers. Foam insulation is placed in the open areas of the frame and the entire roof is covered with plywood and fiberglass. The plywood does not seem to be thick enough and over time the roof will sag between the crossmembers. Link to comment Share on other sites More sharing options...
guy_ethier Posted March 18, 2021 Share Posted March 18, 2021 Terry, As Bob said, some of us have it worse, or different but similar to yours. I am including a photo that I took of our '06 Endeavor that shows "ridges" across the motorhome. While this is not sagging like yours is, the fault with this coach was the thin sheets of luan underneath that separated from the supporting metal frame and bend upwards over time where the luan sheets meet. Bad adhesive job? I have identified 4 of these on my coach and a previous Monaco owner, by the tag of "Flyer" had a similar problem and went back to Harrisburg, Oregon to have it repaired under warranty. They replaced the roof but it appeared shortly afterwards! Apparently he was told by Kay Toolson that it did not need to be replaced and that it was normal. 13 years after we have owned this coach the raised ridges are still there, they have not gotten appreciably worse and there are no leaks. Normal? I don't think so, but I do not think it is a major problem as the filon has enough flex to withstand the upwards bending of the luan sheets underneath them. I routinely inspect them for micro tears but have not seen any since we have owned the rig. I try to avoid walking on them when up there but I occasionally do step on them without damage. Again, this may be different than your sunken parts. As well, the gap you are feeling on the sides of the roof is normal as the roof is one piece and "floats" on top of the frame trusses with nothing but the appliance covers and the weight of them holding them down. They are secured to the metal sidewall frames with screws, that do happen to rust, but the soft feel is normal when pressing down with your hand on the part that laps over each side of the motorhome. The front and rear caps are separate pieces the are sealed with eternabond tape to the one piece roof. Link to comment Share on other sites More sharing options...
Dennis H Posted March 18, 2021 Share Posted March 18, 2021 Notice the "U". Like the "O" for the Ducks....🤣 ...Dennis Link to comment Share on other sites More sharing options...
guy_ethier Posted March 18, 2021 Share Posted March 18, 2021 Dennis, Little bit slow this morning....what do you mean? Link to comment Share on other sites More sharing options...
Bob Nodine Posted March 19, 2021 Share Posted March 19, 2021 17 hours ago, Dennis H said: Notice the "U". Like the "O" for the Ducks....🤣 ...Dennis I do not understand your post. May just be me because I don't keep up with society. Link to comment Share on other sites More sharing options...
Dennis H Posted March 19, 2021 Share Posted March 19, 2021 4 hours ago, Bob Nodine said: I do not understand your post. May just be me because I don't keep up with society. Bob, Cob"U"rg vs Cob"E"rg. City founders are sensitive people....😁..Dennis Link to comment Share on other sites More sharing options...
Bob Nodine Posted March 20, 2021 Share Posted March 20, 2021 17 hours ago, Dennis H said: Bob, Cob"U"rg vs Cob"E"rg. City founders are sensitive people....😁..Dennis Now I see. Good catch. It is amazing what the human brain will tolerate when reading text. You can have half the words drastically misspelled and the brain still knows what the message is. Maybe Bob's fingers got a little silly on the keyboard. Mine do that all the time and if I don't proof read I look like the backward Hillbilly I almost became. Seems as I get older when I type my brain swaps the position of letters like bcak for back. Getting old is not for sissies! 1 Link to comment Share on other sites More sharing options...
guy_ethier Posted March 20, 2021 Share Posted March 20, 2021 Bob, Sorry, I still don't get it. Can you explain it to me in Hillbilly terms? Not being cute, just don't see it?😖 Link to comment Share on other sites More sharing options...
Guest Ray Davis Posted March 20, 2021 Share Posted March 20, 2021 Guy, I'm not Bob but I'll try. Dennis was proof reading and found that Coburg was misspelled as Coberg, most people don't know it's wrong or care. I still haven't quite figured out the O for the Ducks though, must be west coast talk. Spelling and pronouncing city names gets touchy sometimes, For instance there is a small city near Austin here in Tx named Burnet, now most of us pronounce it Bur-net, but locals will tell you quickly that it is pronounced Burn-it. Makes no sense to me, but I don't live there. I probably shouldn't be posting because I know my writing wont stand up to even a little scrutiny. Link to comment Share on other sites More sharing options...
guy_ethier Posted March 20, 2021 Share Posted March 20, 2021 Ray, I guess he was replying, not to the thread topic which was Roof Sagging but, to a town in Oregon that was misspelled twice by previous posts. I get the U in Coburg, not E as in Coberg, but still do not see the reason for the O in Ducks? Unless many people call them Docks? Or is it their season record of 0 wins, which makes even less sense as they are 4-3 this season? Thanks for clarifying the Coburg part. Link to comment Share on other sites More sharing options...
W7BE_Bob Posted March 20, 2021 Share Posted March 20, 2021 When I installed my solar I was able to flex the roof up and down where the panels were attached to the roof near the center because I now had something to pull up. This led to the discovery that the center sloped roof is not attached to the flat ceiling cross beams which are on 4' centers. It is attached where there is additonal structure like A/Cs and vents of course. Eventually I added long aluminum L brackets positioned fore/aft and secured them to the ceiling beams with 2.5" SS screws and then ran an additional support brackets to the panels. Link to comment Share on other sites More sharing options...
Guest terry05dip Posted March 20, 2021 Share Posted March 20, 2021 By chance would you have any photos?. Link to comment Share on other sites More sharing options...
W7BE_Bob Posted March 20, 2021 Share Posted March 20, 2021 Terry, If you're asking me click on the link in my signatrure. Removing ceiling fixtures allowed visibility to parts of the roof. Link to comment Share on other sites More sharing options...
JDCrow Posted March 21, 2021 Share Posted March 21, 2021 University of Oregon U of O Oregon Ducks “O” Is for Oregon Orygun is how it is said here out West Sorry, wanted my first post to be more meaningful Link to comment Share on other sites More sharing options...
Guest Ray Davis Posted March 21, 2021 Share Posted March 21, 2021 Thanks Justin or is JD, either way welcome to the group. I was toying with those things in my mind but was sure I had it mixed up, thank you. Link to comment Share on other sites More sharing options...
JDCrow Posted March 23, 2021 Share Posted March 23, 2021 On 3/21/2021 at 9:17 AM, Ray Davis said: Thanks Justin or is JD, either way welcome to the group. I was toying with those things in my mind but was sure I had it mixed up, thank you. Either way. Mom says Justin, Dad says JD. I’ll try and stay on topic. LOL I have lots to learn, I have roof sag around back AC. Link to comment Share on other sites More sharing options...
