danwegand Posted May 28, 2021 Share Posted May 28, 2021 Hydraulic cylinder replacement Onan 7500 2003 windsor. any venders that carry these cylinders? Dan Wegand 2003 Windsor Link to comment Share on other sites More sharing options...
Dr4Film Posted May 28, 2021 Share Posted May 28, 2021 Dan, Call Mike from Affordable Hose & Fittings in Cincinnati OH at 513-200-4349. http://www.affordablehydraulics.com/ He completely rebuilt my hydraulic generator slide system last year. He is well versed in RV systems and plowing systems. Link to comment Share on other sites More sharing options...
Ivan K Posted May 28, 2021 Share Posted May 28, 2021 Since it appears that you would do the replacement yourself, you would be better off taking the old one to a hydraulics shop for rebuild. Unless yours is physically damaged, new seals are cheap. That way you have no fitment problems and it would be a fraction of a new cost. I had couple of my cylinders rebuilt with same day turnaround. That's what I would do. Link to comment Share on other sites More sharing options...
jacwjames Posted May 28, 2021 Share Posted May 28, 2021 Here is a link to the manual for the slide https://lci-support-doc.s3.amazonaws.com/manuals/power-gear/pg_82_s0298_00.pdf It is a Power Gear system, now owned by Lippert. You might contact them. The cylinder itself is pretty simple, what problems are you having??? In the past I've had problems with the lock valve. It would get hung up and prevent the cylinder from going in/out. I've taken the valve block apart and cleaned, also cleaned /flush the system, which helps but has not completely solved the problem. I even replaced the lock valve one. I carry a socket that fits the nuts on the end of the cylinder stem so I can take it loose and pull the generator slide out if it get hung. If your cylinder is leaking you should be able to take it to a hydraulic shop and get it resealed, should not cost that much. You could try and contact Visione RV which deals in salvage parts, https://usedrvparts.visonerv.com/ If they have a cylinder you'll pay for it. Link to comment Share on other sites More sharing options...
CRY1942 Posted May 28, 2021 Share Posted May 28, 2021 Any hydraulic shop can rebuild (new internal seals) did mine for $240.00 including new hoses. Travel safe. Link to comment Share on other sites More sharing options...
vanwill52 Posted May 29, 2021 Share Posted May 29, 2021 Rebuilt mine last year with parts from a local hydraulics repair shop. Cost of all new seals--approximately $15/ Link to comment Share on other sites More sharing options...
