Dave Houchin Posted May 28, 2021 Share Posted May 28, 2021 I have a 2007 Monaco signature noble lll and I want to know how to program the outside keypad handle. The last time The MH was in the shop they messed up the power to the radios (2) and the keypad access number. Typical experience, the fixed 2 items and messed up 3 or 4. Any help will be appreciated. Thanks, Dave Houchin Link to comment Share on other sites More sharing options...
Ivan K Posted May 28, 2021 Share Posted May 28, 2021 My factory default code to program the keypad was on equipment list in the bedroom cabinet wall. That one should work no matter what, does it? Link to comment Share on other sites More sharing options...
Hypoxia Posted May 28, 2021 Share Posted May 28, 2021 Trimark Instruction Book Link to comment Share on other sites More sharing options...
Dennis H Posted May 29, 2021 Share Posted May 29, 2021 Is it a TriMark or an Essex? Different animals requiring different programming. I hate it when the techs mess up things while fixing other things. Especially when they 'forget' to tell you they messed those other things up. You usually discover them when it's not convenient.......Dennis Link to comment Share on other sites More sharing options...
Dave Houchin Posted May 29, 2021 Author Share Posted May 29, 2021 7 hours ago, Dave Houchin said: I have a 2007 Monaco signature noble lll and I want to know how to program the outside keypad handle. The last time The MH was in the shop they messed up the power to the radios (2) and the keypad access number. Typical experience, the fixed 2 items and messed up 3 or 4. Any help will be appreciated. Thanks, Dave Houchin It’s 45 feet with a ISX 600 hp engine. I don’t know the manufacture of the keypad system Link to comment Share on other sites More sharing options...
Hypoxia Posted May 29, 2021 Share Posted May 29, 2021 The Trimark control is under the cover above the instrument panel. I sometimes have to unplug the power plug on the control and plug it back in to cure a keypad issue. That may be worth trying. Does the keypad beep when you press on the numbers? When my keypad heats up or stops beeping I re-seat the power plug which cures it. Link to comment Share on other sites More sharing options...
96 EVO Posted May 29, 2021 Share Posted May 29, 2021 My entire TriMark system has failed over the last 4 weeks, up to and including all bay door actuators! Tech support at Trimark blames it on the way Monaco mis-wired the boor bell! Link to comment Share on other sites More sharing options...
Hypoxia Posted May 29, 2021 Share Posted May 29, 2021 TriMark Doorbell Modification Link to comment Share on other sites More sharing options...
96 EVO Posted May 29, 2021 Share Posted May 29, 2021 Yeah, I'll need to make that modification when my new components arrive. When I told Kevin at their tech support, that several years ago someone pressed the doorbell button and it kept ringing until I cut the wires to the bell, he said the damage was already done, and it was only a matter of time till that keypad failed. I got several years. Link to comment Share on other sites More sharing options...
Dave Houchin Posted May 29, 2021 Author Share Posted May 29, 2021 41 minutes ago, 96 EVO said: Yeah, I'll need to make that modification when my new components arrive. When I told Kevin at their tech support, that several years ago someone pressed the doorbell button and it kept ringing until I cut the wires to the bell, he said the damage was already done, and it was only a matter of time till that keypad failed. I got several years. I want to thank everyone for their input on programming my door keypad. first the module for my keypad is in the panel beside the passenger door. I printed the manual sent to me for TriMark and from the directions therein, programmed a new entrance code. The Bill D’s site is the greatest way to aid in making repairs, etc. thanks, Dave Houchin Link to comment Share on other sites More sharing options...
Hypoxia Posted May 29, 2021 Share Posted May 29, 2021 I guess that is why Monaco are called snowflakes. They are all different. Link to comment Share on other sites More sharing options...
Dave Houchin Posted May 31, 2021 Author Share Posted May 31, 2021 On 5/29/2021 at 11:58 AM, 96 EVO said: My entire TriMark system has failed over the last 4 weeks, up to and including all bay door actuators! Tech support at Trimark blames it on the way Monaco mis-wired the boor bell! I just reset mine. Get the manual and reset it to the original default setting. Then set your desired code, etc. Try it, it will not cost you anything. Link to comment Share on other sites More sharing options...
96 EVO Posted May 31, 2021 Share Posted May 31, 2021 5 hours ago, Dave Houchin said: I just reset mine. Get the manual and reset it to the original default setting. Then set your desired code, etc. Try it, it will not cost you anything. I wish! Mine is a little more serious than that. Over the course of a couple of weeks, each of the buttons on the keypad started to not beep when pressed. Since then, the key FOB began doing strange things, until all it will do is lock / unlock the entry door. Link to comment Share on other sites More sharing options...
Dave Houchin Posted June 1, 2021 Author Share Posted June 1, 2021 8 hours ago, 96 EVO said: I wish! Mine is a little more serious than that. Over the course of a couple of weeks, each of the buttons on the keypad started to not beep when pressed. Since then, the key FOB began doing strange things, until all it will do is lock / unlock the entry door. I don’t know what to suggest. My fob has always worked. But when I pushed the buttons didn’t beep. Only the door bell worked. I only have one fob and would like to get another to match the original. However, I did buy another but it will not pare to the unit. Possibly a different fm frequency. Link to comment Share on other sites More sharing options...
David Pratt Posted June 1, 2021 Share Posted June 1, 2021 The key pads on the mid 2000's Monaco coaches are known to go bad after time. The early units had a flexible e-poxy sealer under the buttons that got hard over time because of exposure to the sunlight. As it hardened the buttons would get harder to push and would not respond to any input. when they fail they can also put pressure on the internal electronics and causing the key fob to quit responding. Remove the keypad and on the back is a label with the Manufacture's info and part number that you will need to purchase a replacement. If trying to reprogram the old keypad fails, replace it. The replacements do not have the issue. Link to comment Share on other sites More sharing options...
